Spa122
newton.sloan
Is there a way to reduce the noise in a SPA122?
Lycom is has a customer that has a GE Alarm system which is attached that uses 2 loop start lines. I attached the alarm type on email, There is issue is that the Alarm sends the DTMF fast and that our equipment does not keep up, it will not transmit the pulses fast enough. They are saying noise on the line.
Is there any other options with this issues even getting another Device would be great for them them but which one?
paolo bevilacqua
Wrong forum, post in "Small Business voice - ATA and adapters". You can move your posting with the Actions panel on the right.
