SPA2012 ATA Audio output gain
Hasan Mahdi
Hello everyone.
I am using an ATA model SPA2012.
I am having an issue with audio output gain.
In user end, the audio output is too low..
I need to increase the audio output volume/gain.
 Thanks in Advance.
On the Regional tab under Miscellaneous did you try adjusting the "FXS Port Output Gain"?
The default setting is -3. The Administration Guide says
Output gain in dB, up to three decimal places. The range is
6.000 to -12.000. The Call Progress Tones and DTMF
playback level are not affected by the FXS Port Output
Gain parameter.
The default is -3.
