Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
972
bbbbobbbb
Beginner
SPA2102 Malfunction, odd blink pattern...
5 month old SPA2102, been working fine since the day I bought in April of this year. Current firmware (5.2.10).
Yesterday it went into a constant reboot cycle. Powers down, red power led--green power led--power led flash-green internet led-internet led then flashes activity 7-15 flashes, power down.
Swapped power outlet, swapped ethernet cable, switched port on switch, moved to different switch and different ethernet cable on same subnet. No change....
Any ideas?
BB
1 ACCEPTED SOLUTION
Daniele Giordano
Rising star
4 REPLIES 4
Daniele Giordano
Rising star
Bob,
If you've another power supply, try swapping that out first. From the description, it reads like the power supply is not coping.
Patrick
Thanks Patrick for the reply, it was actually the unit and not the power supply.
I RMA'ed the unit on Monday after I placed an order at amazon for another unit. The new unit from amazon arrived yesterday and I plugged it in with the old PS and it is working fine...
BB
Excellent,
I'm pleased to read that you've a functional device again. I appreciate you letting us know.
Patrick
