SPA2102 out-of-memory (H737202d1) errors
albionresearch
I'm seeing intermittent out-of-memory (H737202d1)errors and reboots being reported in the system log from an SPA-2102:
Oct 20 03:39:19 phb4 System started: ip@192.168.1.6, reboot reason:H737202d1
Oct 20 03:39:25 phb4 YM:ERR:AuthServerNotConfig
Oct 20 03:39:25 DOGBERT syslog: last message repeated 3 times
Oct 20 03:39:25 phb4 [0]Reg Addr Change(0) 0:0->ae893fce:5060
Oct 20 03:39:25 phb4 [1]Reg Addr Change(0) 0:0->4df0305e:5060
Oct 20 03:39:43 phb4 System started: ip@192.168.1.6, reboot reason:H737202d1
Oct 20 03:39:48 phb4 YM:ERR:AuthServerNotConfig
Oct 20 03:39:49 DOGBERT syslog: last message repeated 3 times
SPA2102 S/W version is 5.2.10, H/W version is 1.3.5(a).
The events occur when the system is quiescent (no calls in progress or recently made), and more typically at 1 or 2 day intervals.
Has anybody else seen this?
I'm guessing a bug in SIP registration timeout handling as this is possibly occurring when the internet connection is congested.
So far it has been an annoyance rather than a major problem (the phones ring briefly when it happens).
I can switch on more detailed logging if more information is required.
Patrick Born
Hi Michael,
Could be related to external sources.
Take a look at:
Patrick
Patrick Born
Hi Michael,
Take a look at:
Patrick
Patrick,
Thanks for responding. I looked at your initial suggestions.
A DoS seems very unlikely as there's negligible traffic being reported by the firewall router.
(I will, however, enable the Restrict Source IP option on both lines to see if it makes any
difference).
The reboot reason chart was where I found out that H737202d1 was an out-of-memory error.
The SPA2102 is on a wireless connection to the internet which occasionally drops out due to
weather and/or congestion at the local tower - hence my suspicion of a bug in timeout handling
or the handling of lost packets being the cause.
Please let me know if there is any additional information / logging that I could provide.
-- Mike --
UPDATE -
Seem to have solved the problem. Thanks Patrick!
Note that enabling the Restrict Source IP option does cause problems if you make (or receive) calls using IP dialling.
Rather than a targeted DoS attack it looks like there are a number of attempts being made to break into
VoIP systems on port 5060 using a brute force userid/password guessing attack. Presumably
the SPA-2102 fails when this happens. (Better log messages in next release?)
SANS Internet Storm Center http://isc.sans.edu/port.html?port=5060 gives some idea of the
number of attempts.  This blog entry http://blog.tridgell.net/?p=28 describes a successful brute force
attack against an Asterisk server.
Looks like a bad idea to use the default 5060 port unless you have to.
Message was edited by: Michael Bell (added UPDATE)
