SPA2102 Power light RED
lirone
I got some SPA2102 that got the power light red blinking slowly
Any idea how to fix them ?
Best Regards
Alberto Montilla
Dear Sir;
Is the device accessible, i.e. can you access the web-ui? This error is typically related when the device either cannot fetch to a configuration file or due to a DNS error.
Please try accessing the Web-UI first. If successful, then issue may be on the configuration, not the device itself.
Alberto
It's not possible to access the gateway nor via the web ui nor via the ****
The computer don't get any IP
Any idea ?
Hi Lirone;
Could you please check which of the blink patterns of the power LED your case match to
https://supportforums.cisco.com/docs/DOC-9901
Alberto
