Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
228
braymond1963
Beginner
SPA302D - Background noise during call on headset connect to 2.5mm
Hi team,
Has anyone used a headset connected to the 302D through the 2.5mm jack and had a good quality call? If I call by not using a headset, the sound is just great but if I hook up a headset into the jack, there's a lot of steady background noise that is quite irritating. The "speaking part" is fine; meaning the callee hears me fine.
I tried using the same headset to an analog phone that has a 2.5mm jack and I don't have this background noise so it has to either be some hardware incompatibility issue or some software problem that generates noise!!!
So if someone has good result with a headset connected to the 302D, I would appreciate to know which model is being used.
Benoit Raymond
TelSip Communication
0 REPLIES 0
