SPA3102 FXO port problem
jutuckey
I'm having troubles with incoming calls. These calls are ringing on FXS ports, but I need this calls to connect with the IP PBX "Eolix" (FXO Port). I can call from any phone, the only trouble is that the incomings calls are not connecting with the IP PBX.
I have updated the firmware, but nothing happened. Can anyone helpme?
Thanks in advance!
Juan.-
Patrick Born
Hi Juan,
Have you ever had inbound calls flowing the way you want?
Is this a new configuration?
Please send your configuration to me at paborn at Cisco for analysis: https://www.myciscocommunity.com/docs/DOC-5101
I am out tomorrow, so I will analyze the config on Thursday when I return.
Patrick
