05-14-2011 07:40 AM - edited 03-21-2019 09:35 AM
For USER english:
Scenario:
1 spa 3102 - 1001 User
A SIP server
1 spa 921 - 101 user
1 spa 922 - 102 user
This is what happens:
101 user call external line to 0622222 ....
sip server route call on SPA3102
spa 3102 call 0622222 .... and connects with 101
While the two talk 102 tries to make a call and bind the PSTN line 1001
spa 3102 responds with the message 503 (correctly because the line is busy state)
102 close call
After a few seconds when 101 and 0622222 .... are still connected, spa 3102 sends an invitation to sip server containing the two people in line.
Send an invitation as if it were a new incoming call, but it is the same as before.
Is there any setting to configure to prevent them, what does not happen?
Solved! Go to Solution.
05-18-2011 10:49 AM
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center.
I would like to make sure that I understand your issue correctly:
If I am correct, then it I feel that this may be to much to try and troubleshoot through email on this forum. My best suggestion would be give our support center a call and let one of our VOIP agents help resolve this issue.
You can contact the SMall Business Support Cent at 1-866-606-1866 or contact our Sophia, Bulgaria support center at +442077603350
Eric Moyers
Cisco Network Support Engineer
1-866-606-1866
05-18-2011 10:49 AM
Eric Moyers
1-866-606-1866
05-18-2011 02:23 PM
Hi Eric Moyers,
this is a bug of version 5.0, in last version this issue is solved.
Gianfranco
