04-05-2013 02:51 AM - edited 03-21-2019 10:01 AM
I live in Portugal, and have a SPA3012 connected to a PSTN line of Portugal Telecom (via the FXO port), and a normal telephone connected to the SPA3102's FXS port. During an incoming call on the PSTN line, the phone rings and shows the caller ID correctly. However, after approx. 3 rings, the caller ID display disappears, and then shows again as "unknown number". The phone keeps ringing, but the phone thinks this is now a new call.
In other words, the single incoming call looks to the phone like 2 or 3 (or more, if I let it ring longer) separate calls, each of about 3 rings (the phone's log confirms this). The caller ID only is shown for the first one, the subsequent ones show up as "unknown" (which makes sense, since after the 3rd ring of course no new caller ID code was transmitted).
If I answer the call, most of the time it is OK (connection made), but if I answer just after the 3rd ring (or the 6th or 9th), then the SPA3102 will *not* answer the incoming call, but give me a VOIP dialtone for an outgoing call instead. So it seems that I am answering the call in the "break" between what the SPA3102 thinks are multiple incoming calls. If I just hang up (after getting the VOIP dialtone), the phone will then continue to ring.
I have tried this on different local PSTN lines (to make sure it's not a line problem), and also with different phones connected to the SPA3102 (to make sure it's not a phone issue).
So I think it must be a configuration problem of the SPA3102. I have configured it according to this guide from Portugal Telecom: Link
Any ideas what I might need to change to fix this?
Many thanks in advance!
04-05-2013 06:53 AM
04-11-2013 12:56 AM
Thanks for the suggestion! I captured a syslog of an incoming call on the PSTN line (I just let it ring several times without answering the call), and the phone registered it as 2 or 3 separate calls (first one showing the correct caller ID, then the subsequent "calls" showing "unknown caller").
Log:
09/04/2013 20:55,Debug,192.168.1.86,
09/04/2013 20:55,Debug,192.168.1.86,OP:STUNTS = 16 ( 16 68)
09/04/2013 20:55,Debug,192.168.1.86,OP:SUBDLG = 2 ( 2 6444)
09/04/2013 20:55,Debug,192.168.1.86,OP:SIPLIN = 0 ( 2 140)
09/04/2013 20:55,Debug,192.168.1.86,OP:SIPREG = 3 ( 4 468)
09/04/2013 20:55,Debug,192.168.1.86,OP:SIPSES = 12 ( 12 8192)
09/04/2013 20:55,Debug,192.168.1.86,OP:SIPDLG = 10 ( 10 148)
09/04/2013 20:55,Debug,192.168.1.86,OP:SIPAUS = 0 ( 8 588)
09/04/2013 20:55,Debug,192.168.1.86,OP:SIPSTS = 32 ( 32 6064)
09/04/2013 20:55,Debug,192.168.1.86,OP:SIPCTS = 32 ( 32 580)
09/04/2013 20:55,Debug,192.168.1.86,OP:SIPCOR = 0 ( 1 28)
09/04/2013 20:55,Debug,192.168.1.86,OP:TIMEOU = 111 (120 52)
09/04/2013 20:55,Debug,192.168.1.86,OP:RTPTXB = 64 ( 64 108)
09/04/2013 20:55,Debug,192.168.1.86,OP:RTPREB = 40 ( 40 48)
09/04/2013 20:55,Debug,192.168.1.86,OP:RTPRXB = 96 ( 96 192)
09/04/2013 20:55,Debug,192.168.1.86,--- OBJ POOL STAT ---
09/04/2013 20:55,Debug,192.168.1.86,CC:Clean Up
09/04/2013 20:55,Debug,192.168.1.86,Sess Terminated
09/04/2013 20:55,Debug,192.168.1.86,DLG Terminated 2e2da4
09/04/2013 20:55,Info,192.168.1.86,
09/04/2013 20:55,Debug,192.168.1.86,ACK sip:+351289934899@127.0.0.1:5060 SIP/2.0\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-86817105\0x0D\0x0AFrom: <192.168.1.86>;tag=4b8d5800f1ef384do1\0x0D\0x0ATo: <>;tag=27bbeb0ecf3c1099i0\0x0D\0x0ACall-ID: 68089c3c-f8446141@192.168.1.86\0x0D\0x0ACSeq: 101 ACK\0x0D\0x0AMax-Forwards: 70\0x0D\0x0AContact: <192.168.1.86:5061>\0x0D\0x0AUser-Agent: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86:5061>>192.168.1.86>
09/04/2013 20:55,Info,192.168.1.86,[0]<<127.0.0.1:5061(385)
09/04/2013 20:55,Debug,192.168.1.86,DLG Terminated 2e32d8
09/04/2013 20:55,Debug,192.168.1.86,CC:Ended
09/04/2013 20:55,Debug,192.168.1.86,[0:0]AUD Rel Call
09/04/2013 20:55,Debug,192.168.1.86,[0]FM Alert Stop RxTx (c=0024e22c;a=0)
09/04/2013 20:55,Debug,192.168.1.86,SIP/2.0 200 OK\0x0D\0x0ATo: <>;tag=27bbeb0ecf3c1099i0\0x0D\0x0AFrom: <192.168.1.86>;tag=4b8d5800f1ef384do1\0x0D\0x0ACall-ID: 68089c3c-f8446141@192.168.1.86\0x0D\0x0ACSeq: 101 CANCEL\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-86817105\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86>>
09/04/2013 20:55,Info,192.168.1.86,[0]->127.0.0.1:5061(302)
09/04/2013 20:55,Debug,192.168.1.86,SIP/2.0 487 Request Terminated\0x0D\0x0ATo: <>;tag=27bbeb0ecf3c1099i0\0x0D\0x0AFrom: <192.168.1.86>;tag=4b8d5800f1ef384do1\0x0D\0x0ACall-ID: 68089c3c-f8446141@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-86817105\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86>>
09/04/2013 20:55,Info,192.168.1.86,[0]->127.0.0.1:5061(318)
09/04/2013 20:55,Debug,192.168.1.86,CANCEL sip:+351289934899@127.0.0.1:5060 SIP/2.0\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-86817105\0x0D\0x0AFrom: <192.168.1.86>;tag=4b8d5800f1ef384do1\0x0D\0x0ATo: <>\0x0D\0x0ACall-ID: 68089c3c-f8446141@192.168.1.86\0x0D\0x0ACSeq: 101 CANCEL\0x0D\0x0AMax-Forwards: 70\0x0D\0x0AUser-Agent: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0>192.168.1.86>
09/04/2013 20:55,Info,192.168.1.86,[0]<<127.0.0.1:5061(334)
09/04/2013 20:55,Debug,192.168.1.86,[1:0]AUD Rel Call
09/04/2013 20:55,Debug,192.168.1.86,[0]FM Alert Stop RxTx (c=0025422c;a=0)
09/04/2013 20:55,Debug,192.168.1.86,FXO:Stop CNDD
09/04/2013 20:55,Debug,192.168.1.86,AUD:Stop PSTN Tone
09/04/2013 20:55,Debug,192.168.1.86,FXO:On Hook
09/04/2013 20:55,Debug,192.168.1.86,AUD:Play PSTN Tone 9
09/04/2013 20:55,Debug,192.168.1.86,[1:0]RTP Rx Dn
09/04/2013 20:55,Debug,192.168.1.86,CC:Ringback
09/04/2013 20:55,Debug,192.168.1.86,SIP/2.0 180 Ringing\0x0D\0x0ATo: <>;tag=27bbeb0ecf3c1099i0\0x0D\0x0AFrom: <192.168.1.86>;tag=4b8d5800f1ef384do1\0x0D\0x0ACall-ID: 68089c3c-f8446141@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-86817105\0x0D\0x0AContact: +351289934899 <>\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0ARemote-Party-ID: +351289934899 <>>>192.168.1.86>>+351289934899@sip.freevoipdeal.com>;screen=yes;party=called\0x0D\0x0AContent-Length: 0
09/04/2013 20:55,Info,192.168.1.86,[0]->127.0.0.1:5061(466)
09/04/2013 20:55,Debug,192.168.1.86,[0:0]RTP Rx Up
09/04/2013 20:55,Debug,192.168.1.86,[0:0]AUD ALLOC CALL (port=16400)
09/04/2013 20:55,Debug,192.168.1.86,SDP RTPMAP 101 --> 136
09/04/2013 20:55,Debug,192.168.1.86,SDP RTPMAP 100 --> 134
09/04/2013 20:55,Debug,192.168.1.86,SIP/2.0 100 Trying\0x0D\0x0ATo: <>\0x0D\0x0AFrom: <192.168.1.86>;tag=4b8d5800f1ef384do1\0x0D\0x0ACall-ID: 68089c3c-f8446141@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-86817105\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86>>
09/04/2013 20:55,Info,192.168.1.86,[0]->127.0.0.1:5061(283)
09/04/2013 20:55,Debug,192.168.1.86,INVITE sip:+351289934899@127.0.0.1:5060 SIP/2.0\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-86817105\0x0D\0x0AFrom: <192.168.1.86>;tag=4b8d5800f1ef384do1\0x0D\0x0ATo: <>\0x0D\0x0ARemote-Party-ID: <192.168.1.86>;screen=yes;party=calling\0x0D\0x0AAlert-Info: Bellcore-r1\0x0D\0x0ACall-ID: 68089c3c-f8446141@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AMax-Forwards: 70\0x0D\0x0AContact: <192.168.1.86:5061>\0x0D\0x0AExpires: 240\0x0D\0x0AUser-Agent: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 255\0x0D\0x0AAllow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER\0x0D\0x0ASupported: x-sipura, replaces\0x0D\0x0AContent-Type: application/sdp\0x0D\0x0A\0x0D\0x0Av=0\0x0D\0x0Ao=- 5733838 5733838 IN IP4 192.168.1.86\0x0D\0x0As=-\0x0D\0x0Ac=IN IP4 192.168.1.86\0x0D\0x0At=0 0\0x0D\0x0Am=audio 16398 RTP/AVP 0 100 101\0x0D\0x0Aa=rtpmap:0 PCMU/8000\0x0D\0x0Aa=rtpmap:100 NSE/8000\0x0D\0x0Aa=fmtp:100 192-193\0x0D\0x0Aa=rtpmap:101 telephone-event/8000\0x0D\0x0Aa=fmtp:101 0-15\0x0D\0x0Aa=ptime:30\0x0D\0x0Aa=sendrecv192.168.1.86:5061>192.168.1.86>>192.168.1.86>
09/04/2013 20:55,Info,192.168.1.86,[0]<<127.0.0.1:5061(851)
09/04/2013 20:55,Debug,192.168.1.86,[1:0]RTP Rx Up
09/04/2013 20:55,Debug,192.168.1.86,[1:0]AUD ALLOC CALL (port=16398)
09/04/2013 20:55,Debug,192.168.1.86,Calling:+351289934899@127.0.0.1:5060
09/04/2013 20:55,Debug,192.168.1.86,FXO:Start CNDD
09/04/2013 20:55,Debug,192.168.1.86,DLG Terminated 2e3244
09/04/2013 20:55,Debug,192.168.1.86,ACK sip:+351289934899@127.0.0.1:5060 SIP/2.0\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-8087a9a5\0x0D\0x0AFrom: <192.168.1.86>;tag=122038fbcab7d135o1\0x0D\0x0ATo: <>;tag=d9ea0895f299b665i0\0x0D\0x0ACall-ID: 9ee0b0f3-f6d4f99d@192.168.1.86\0x0D\0x0ACSeq: 101 ACK\0x0D\0x0AMax-Forwards: 70\0x0D\0x0AContact: <192.168.1.86:5061>\0x0D\0x0AUser-Agent: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86:5061>>192.168.1.86>
09/04/2013 20:55,Debug,192.168.1.86,DLG Terminated 2e31b0
09/04/2013 20:55,Debug,192.168.1.86,SIP/2.0 200 OK\0x0D\0x0ATo: <>;tag=d9ea0895f299b665i0\0x0D\0x0AFrom: <192.168.1.86>;tag=122038fbcab7d135o1\0x0D\0x0ACall-ID: 9ee0b0f3-f6d4f99d@192.168.1.86\0x0D\0x0ACSeq: 101 CANCEL\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-8087a9a5\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86>>
09/04/2013 20:55,Debug,192.168.1.86,SIP/2.0 487 Request Terminated\0x0D\0x0ATo: <>;tag=d9ea0895f299b665i0\0x0D\0x0AFrom: <192.168.1.86>;tag=122038fbcab7d135o1\0x0D\0x0ACall-ID: 9ee0b0f3-f6d4f99d@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-8087a9a5\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86>>
09/04/2013 20:55,Debug,192.168.1.86,CANCEL sip:+351289934899@127.0.0.1:5060 SIP/2.0\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-8087a9a5\0x0D\0x0AFrom: <192.168.1.86>;tag=122038fbcab7d135o1\0x0D\0x0ATo: <>\0x0D\0x0ACall-ID: 9ee0b0f3-f6d4f99d@192.168.1.86\0x0D\0x0ACSeq: 101 CANCEL\0x0D\0x0AMax-Forwards: 70\0x0D\0x0AUser-Agent: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0>192.168.1.86>
09/04/2013 20:55,Debug,192.168.1.86,SIP/2.0 180 Ringing\0x0D\0x0ATo: <>;tag=d9ea0895f299b665i0\0x0D\0x0AFrom: <192.168.1.86>;tag=122038fbcab7d135o1\0x0D\0x0ACall-ID: 9ee0b0f3-f6d4f99d@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-8087a9a5\0x0D\0x0AContact: +351289934899 <>\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0ARemote-Party-ID: +351289934899 <>>>192.168.1.86>>+351289934899@sip.freevoipdeal.com>;screen=yes;party=called\0x0D\0x0AContent-Length: 0
09/04/2013 20:55,Debug,192.168.1.86,[0:0]AUD ALLOC CALL (port=16396)
09/04/2013 20:55,Debug,192.168.1.86,SIP/2.0 100 Trying\0x0D\0x0ATo: <>\0x0D\0x0AFrom: <192.168.1.86>;tag=122038fbcab7d135o1\0x0D\0x0ACall-ID: 9ee0b0f3-f6d4f99d@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-8087a9a5\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86>>
09/04/2013 20:55,Debug,192.168.1.86,INVITE sip:+351289934899@127.0.0.1:5060 SIP/2.0\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-8087a9a5\0x0D\0x0AFrom: <192.168.1.86>;tag=122038fbcab7d135o1\0x0D\0x0ATo: <>\0x0D\0x0ARemote-Party-ID: <192.168.1.86>;screen=yes;party=calling\0x0D\0x0AAlert-Info: Bellcore-r1\0x0D\0x0ACall-ID: 9ee0b0f3-f6d4f99d@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AMax-Forwards: 70\0x0D\0x0AContact: <192.168.1.86:5061>\0x0D\0x0AExpires: 240\0x0D\0x0AUser-Agent: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 255\0x0D\0x0AAllow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER\0x0D\0x0ASupported: x-sipura, replaces\0x0D\0x0AContent-Type: application/sdp\0x0D\0x0A\0x0D\0x0Av=0\0x0D\0x0Ao=- 5733237 5733237 IN IP4 192.168.1.86\0x0D\0x0As=-\0x0D\0x0Ac=IN IP4 192.168.1.86\0x0D\0x0At=0 0\0x0D\0x0Am=audio 16394 RTP/AVP 0 100 101\0x0D\0x0Aa=rtpmap:0 PCMU/8000\0x0D\0x0Aa=rtpmap:100 NSE/8000\0x0D\0x0Aa=fmtp:100 192-193\0x0D\0x0Aa=rtpmap:101 telephone-event/8000\0x0D\0x0Aa=fmtp:101 0-15\0x0D\0x0Aa=ptime:30\0x0D\0x0Aa=sendrecv192.168.1.86:5061>192.168.1.86>>192.168.1.86>
09/04/2013 20:55,Debug,192.168.1.86,[1:0]AUD ALLOC CALL (port=16394)
09/04/2013 20:55,Debug,192.168.1.86,DLG Terminated 2e311c
09/04/2013 20:55,Debug,192.168.1.86,ACK sip:+351289934899@127.0.0.1:5060 SIP/2.0\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-16e79d04\0x0D\0x0AFrom: <192.168.1.86>;tag=1cc0cbdf6213b94co1\0x0D\0x0ATo: <>;tag=5d00126d7b9b7418i0\0x0D\0x0ACall-ID: e383b19b-ab29aec0@192.168.1.86\0x0D\0x0ACSeq: 101 ACK\0x0D\0x0AMax-Forwards: 70\0x0D\0x0AContact: <192.168.1.86:5061>\0x0D\0x0AUser-Agent: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86:5061>>192.168.1.86>
09/04/2013 20:55,Debug,192.168.1.86,DLG Terminated 2e3088
09/04/2013 20:55,Debug,192.168.1.86,SIP/2.0 200 OK\0x0D\0x0ATo: <>;tag=5d00126d7b9b7418i0\0x0D\0x0AFrom: <192.168.1.86>;tag=1cc0cbdf6213b94co1\0x0D\0x0ACall-ID: e383b19b-ab29aec0@192.168.1.86\0x0D\0x0ACSeq: 101 CANCEL\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-16e79d04\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86>>
09/04/2013 20:55,Debug,192.168.1.86,SIP/2.0 487 Request Terminated\0x0D\0x0ATo: <>;tag=5d00126d7b9b7418i0\0x0D\0x0AFrom: <192.168.1.86>;tag=1cc0cbdf6213b94co1\0x0D\0x0ACall-ID: e383b19b-ab29aec0@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-16e79d04\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86>>
09/04/2013 20:55,Debug,192.168.1.86,CANCEL sip:+351289934899@127.0.0.1:5060 SIP/2.0\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-16e79d04\0x0D\0x0AFrom: <192.168.1.86>;tag=1cc0cbdf6213b94co1\0x0D\0x0ATo: <>\0x0D\0x0ACall-ID: e383b19b-ab29aec0@192.168.1.86\0x0D\0x0ACSeq: 101 CANCEL\0x0D\0x0AMax-Forwards: 70\0x0D\0x0AUser-Agent: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0>192.168.1.86>
09/04/2013 20:54,Debug,192.168.1.86,IDBG:rs:12
09/04/2013 20:54,Debug,192.168.1.86,IDBG:sc-0
09/04/2013 20:54,Debug,192.168.1.86,AUD:Play PSTN Tone 9
09/04/2013 20:54,Debug,192.168.1.86,[1:0]RTP Rx Dn
09/04/2013 20:54,Debug,192.168.1.86,CC:Ringback
09/04/2013 20:54,Info,192.168.1.86,
09/04/2013 20:54,Debug,192.168.1.86,SIP/2.0 180 Ringing\0x0D\0x0ATo: <>;tag=5d00126d7b9b7418i0\0x0D\0x0AFrom: <192.168.1.86>;tag=1cc0cbdf6213b94co1\0x0D\0x0ACall-ID: e383b19b-ab29aec0@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-16e79d04\0x0D\0x0AContact: +351289934899 <>\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0ARemote-Party-ID: +351289934899 <>>>192.168.1.86>>+351289934899@sip.freevoipdeal.com>;screen=yes;party=called\0x0D\0x0AContent-Length: 0
09/04/2013 20:54,Info,192.168.1.86,[0]->127.0.0.1:5061(466)
09/04/2013 20:54,Debug,192.168.1.86,[0:0]RTP Rx Up
09/04/2013 20:54,Debug,192.168.1.86,[0:0]AUD ALLOC CALL (port=16392)
09/04/2013 20:54,Debug,192.168.1.86,SDP RTPMAP 101 --> 136
09/04/2013 20:54,Debug,192.168.1.86,SDP RTPMAP 100 --> 134
09/04/2013 20:54,Debug,192.168.1.86,SIP/2.0 100 Trying\0x0D\0x0ATo: <>\0x0D\0x0AFrom: <192.168.1.86>;tag=1cc0cbdf6213b94co1\0x0D\0x0ACall-ID: e383b19b-ab29aec0@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-16e79d04\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86>>
09/04/2013 20:54,Info,192.168.1.86,[0]->127.0.0.1:5061(283)
09/04/2013 20:54,Debug,192.168.1.86,INVITE sip:+351289934899@127.0.0.1:5060 SIP/2.0\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-16e79d04\0x0D\0x0AFrom: <192.168.1.86>;tag=1cc0cbdf6213b94co1\0x0D\0x0ATo: <>\0x0D\0x0ARemote-Party-ID: <192.168.1.86>;screen=yes;party=calling\0x0D\0x0AAlert-Info: Bellcore-r1\0x0D\0x0ACall-ID: e383b19b-ab29aec0@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AMax-Forwards: 70\0x0D\0x0AContact: <192.168.1.86:5061>\0x0D\0x0AExpires: 240\0x0D\0x0AUser-Agent: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 255\0x0D\0x0AAllow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER\0x0D\0x0ASupported: x-sipura, replaces\0x0D\0x0AContent-Type: application/sdp\0x0D\0x0A\0x0D\0x0Av=0\0x0D\0x0Ao=- 5732640 5732640 IN IP4 192.168.1.86\0x0D\0x0As=-\0x0D\0x0Ac=IN IP4 192.168.1.86\0x0D\0x0At=0 0\0x0D\0x0Am=audio 16390 RTP/AVP 0 100 101\0x0D\0x0Aa=rtpmap:0 PCMU/8000\0x0D\0x0Aa=rtpmap:100 NSE/8000\0x0D\0x0Aa=fmtp:100 192-193\0x0D\0x0Aa=rtpmap:101 telephone-event/8000\0x0D\0x0Aa=fmtp:101 0-15\0x0D\0x0Aa=ptime:30\0x0D\0x0Aa=sendrecv192.168.1.86:5061>192.168.1.86>>192.168.1.86>
09/04/2013 20:54,Info,192.168.1.86,[0]<<127.0.0.1:5061(851)
09/04/2013 20:54,Debug,192.168.1.86,[1:0]RTP Rx Up
09/04/2013 20:54,Debug,192.168.1.86,[1:0]AUD ALLOC CALL (port=16390)
09/04/2013 20:54,Debug,192.168.1.86,Calling:+351289934899@127.0.0.1:5060
09/04/2013 20:54,Debug,192.168.1.86,FXO:Start CNDD
09/04/2013 20:54,Debug,192.168.1.86,Sess Terminated
09/04/2013 20:54,Debug,192.168.1.86,DLG Terminated 2e2f60
09/04/2013 20:54,Debug,192.168.1.86,ACK sip:+351289934899@127.0.0.1:5060 SIP/2.0\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-9a667eaa\0x0D\0x0AFrom: <192.168.1.86>;tag=c15bc7429f98baeao1\0x0D\0x0ATo: <>;tag=b16b2aa41a48def2i0\0x0D\0x0ACall-ID: 7cc32022-75be378a@192.168.1.86\0x0D\0x0ACSeq: 101 ACK\0x0D\0x0AMax-Forwards: 70\0x0D\0x0AContact: <192.168.1.86:5061>\0x0D\0x0AUser-Agent: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86:5061>>192.168.1.86>
09/04/2013 20:54,Info,192.168.1.86,[0]<<127.0.0.1:5061(385)
09/04/2013 20:54,Debug,192.168.1.86,DLG Terminated 2e2ff4
09/04/2013 20:54,Debug,192.168.1.86,CC:Ended
09/04/2013 20:54,Debug,192.168.1.86,[0:0]AUD Rel Call
09/04/2013 20:54,Debug,192.168.1.86,[0]FM Alert Stop RxTx (c=0024e22c;a=0)
09/04/2013 20:54,Debug,192.168.1.86,SIP/2.0 200 OK\0x0D\0x0ATo: <>;tag=b16b2aa41a48def2i0\0x0D\0x0AFrom: <192.168.1.86>;tag=c15bc7429f98baeao1\0x0D\0x0ACall-ID: 7cc32022-75be378a@192.168.1.86\0x0D\0x0ACSeq: 101 CANCEL\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-9a667eaa\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86>>
09/04/2013 20:54,Info,192.168.1.86,[0]->127.0.0.1:5061(302)
09/04/2013 20:54,Debug,192.168.1.86,SIP/2.0 487 Request Terminated\0x0D\0x0ATo: <>;tag=b16b2aa41a48def2i0\0x0D\0x0AFrom: <192.168.1.86>;tag=c15bc7429f98baeao1\0x0D\0x0ACall-ID: 7cc32022-75be378a@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-9a667eaa\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86>>
09/04/2013 20:54,Info,192.168.1.86,[0]->127.0.0.1:5061(318)
09/04/2013 20:54,Debug,192.168.1.86,CANCEL sip:+351289934899@127.0.0.1:5060 SIP/2.0\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-9a667eaa\0x0D\0x0AFrom: <192.168.1.86>;tag=c15bc7429f98baeao1\0x0D\0x0ATo: <>\0x0D\0x0ACall-ID: 7cc32022-75be378a@192.168.1.86\0x0D\0x0ACSeq: 101 CANCEL\0x0D\0x0AMax-Forwards: 70\0x0D\0x0AUser-Agent: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0>192.168.1.86>
09/04/2013 20:54,Info,192.168.1.86,[0]<<127.0.0.1:5061(334)
09/04/2013 20:54,Debug,192.168.1.86,[1:0]AUD Rel Call
09/04/2013 20:54,Debug,192.168.1.86,[0]FM Alert Stop RxTx (c=0025422c;a=0)
09/04/2013 20:54,Debug,192.168.1.86,FXO:Stop CNDD
09/04/2013 20:54,Debug,192.168.1.86,AUD:Stop PSTN Tone
09/04/2013 20:54,Debug,192.168.1.86,FXO:On Hook
09/04/2013 20:54,Debug,192.168.1.86,SIP/2.0 180 Ringing\0x0D\0x0ATo: <>;tag=b16b2aa41a48def2i0\0x0D\0x0AFrom: <192.168.1.86>;tag=c15bc7429f98baeao1\0x0D\0x0ACall-ID: 7cc32022-75be378a@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-9a667eaa\0x0D\0x0AContact: +351289934899 <>\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0ARemote-Party-ID: +351289934899 <>>>192.168.1.86>>+351289934899@sip.freevoipdeal.com>;screen=yes;party=called\0x0D\0x0AContent-Length: 0
09/04/2013 20:54,Debug,192.168.1.86,[0:0]AUD ALLOC CALL (port=16388)
09/04/2013 20:54,Debug,192.168.1.86,SIP/2.0 100 Trying\0x0D\0x0ATo: <>\0x0D\0x0AFrom: <192.168.1.86>;tag=c15bc7429f98baeao1\0x0D\0x0ACall-ID: 7cc32022-75be378a@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-9a667eaa\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86>>
09/04/2013 20:54,Debug,192.168.1.86,INVITE sip:+351289934899@127.0.0.1:5060 SIP/2.0\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-9a667eaa\0x0D\0x0AFrom: <192.168.1.86>;tag=c15bc7429f98baeao1\0x0D\0x0ATo: <>\0x0D\0x0ARemote-Party-ID: <192.168.1.86>;screen=yes;party=calling\0x0D\0x0AAlert-Info: Bellcore-r1\0x0D\0x0ACall-ID: 7cc32022-75be378a@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AMax-Forwards: 70\0x0D\0x0AContact: <192.168.1.86:5061>\0x0D\0x0AExpires: 240\0x0D\0x0AUser-Agent: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 255\0x0D\0x0AAllow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER\0x0D\0x0ASupported: x-sipura, replaces\0x0D\0x0AContent-Type: application/sdp\0x0D\0x0A\0x0D\0x0Av=0\0x0D\0x0Ao=- 5732037 5732037 IN IP4 192.168.1.86\0x0D\0x0As=-\0x0D\0x0Ac=IN IP4 192.168.1.86\0x0D\0x0At=0 0\0x0D\0x0Am=audio 16386 RTP/AVP 0 100 101\0x0D\0x0Aa=rtpmap:0 PCMU/8000\0x0D\0x0Aa=rtpmap:100 NSE/8000\0x0D\0x0Aa=fmtp:100 192-193\0x0D\0x0Aa=rtpmap:101 telephone-event/8000\0x0D\0x0Aa=fmtp:101 0-15\0x0D\0x0Aa=ptime:30\0x0D\0x0Aa=sendrecv192.168.1.86:5061>192.168.1.86>>192.168.1.86>
09/04/2013 20:54,Debug,192.168.1.86,[1:0]AUD ALLOC CALL (port=16386)
09/04/2013 20:54,Debug,192.168.1.86,DLG Terminated 2e2e38
09/04/2013 20:54,Debug,192.168.1.86,ACK sip:+351289934899@127.0.0.1:5060 SIP/2.0\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-3752516b\0x0D\0x0AFrom: <192.168.1.86>;tag=835cf5c32b3bf43o1\0x0D\0x0ATo: <>;tag=487f0c82b5ac3457i0\0x0D\0x0ACall-ID: 8fb23010-df09b61f@192.168.1.86\0x0D\0x0ACSeq: 101 ACK\0x0D\0x0AMax-Forwards: 70\0x0D\0x0AContact: <192.168.1.86:5061>\0x0D\0x0AUser-Agent: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86:5061>>192.168.1.86>
09/04/2013 20:54,Info,192.168.1.86,[0]<<127.0.0.1:5061(384)
09/04/2013 20:54,Debug,192.168.1.86,DLG Terminated 2e2ecc
09/04/2013 20:54,Debug,192.168.1.86,SIP/2.0 200 OK\0x0D\0x0ATo: <>;tag=487f0c82b5ac3457i0\0x0D\0x0AFrom: <192.168.1.86>;tag=835cf5c32b3bf43o1\0x0D\0x0ACall-ID: 8fb23010-df09b61f@192.168.1.86\0x0D\0x0ACSeq: 101 CANCEL\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-3752516b\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86>>
09/04/2013 20:54,Info,192.168.1.86,[0]->127.0.0.1:5061(301)
09/04/2013 20:54,Debug,192.168.1.86,SIP/2.0 487 Request Terminated\0x0D\0x0ATo: <>;tag=487f0c82b5ac3457i0\0x0D\0x0AFrom: <192.168.1.86>;tag=835cf5c32b3bf43o1\0x0D\0x0ACall-ID: 8fb23010-df09b61f@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-3752516b\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86>>
09/04/2013 20:54,Info,192.168.1.86,[0]->127.0.0.1:5061(317)
09/04/2013 20:54,Debug,192.168.1.86,CANCEL sip:+351289934899@127.0.0.1:5060 SIP/2.0\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-3752516b\0x0D\0x0AFrom: <192.168.1.86>;tag=835cf5c32b3bf43o1\0x0D\0x0ATo: <>\0x0D\0x0ACall-ID: 8fb23010-df09b61f@192.168.1.86\0x0D\0x0ACSeq: 101 CANCEL\0x0D\0x0AMax-Forwards: 70\0x0D\0x0AUser-Agent: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0>192.168.1.86>
09/04/2013 20:54,Info,192.168.1.86,[0]<<127.0.0.1:5061(333)
09/04/2013 20:54,Debug,192.168.1.86,SIP/2.0 180 Ringing\0x0D\0x0ATo: <>;tag=487f0c82b5ac3457i0\0x0D\0x0AFrom: <192.168.1.86>;tag=835cf5c32b3bf43o1\0x0D\0x0ACall-ID: 8fb23010-df09b61f@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-3752516b\0x0D\0x0AContact: +351289934899 <>\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0ARemote-Party-ID: +351289934899 <>>>192.168.1.86>>+351289934899@sip.freevoipdeal.com>;screen=yes;party=called\0x0D\0x0AContent-Length: 0
09/04/2013 20:54,Info,192.168.1.86,[0]->127.0.0.1:5061(465)
09/04/2013 20:54,Debug,192.168.1.86,[0:0]AUD ALLOC CALL (port=16384)
09/04/2013 20:54,Debug,192.168.1.86,SIP/2.0 100 Trying\0x0D\0x0ATo: <>\0x0D\0x0AFrom: <192.168.1.86>;tag=835cf5c32b3bf43o1\0x0D\0x0ACall-ID: 8fb23010-df09b61f@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-3752516b\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86>>
09/04/2013 20:54,Info,192.168.1.86,[0]->127.0.0.1:5061(282)
09/04/2013 20:54,Debug,192.168.1.86,INVITE sip:+351289934899@127.0.0.1:5060 SIP/2.0\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-3752516b\0x0D\0x0AFrom: <192.168.1.86>;tag=835cf5c32b3bf43o1\0x0D\0x0ATo: <>\0x0D\0x0ARemote-Party-ID: <192.168.1.86>;screen=yes;party=calling\0x0D\0x0AAlert-Info: Bellcore-r1\0x0D\0x0ACall-ID: 8fb23010-df09b61f@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AMax-Forwards: 70\0x0D\0x0AContact: <192.168.1.86:5061>\0x0D\0x0AExpires: 240\0x0D\0x0AUser-Agent: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 255\0x0D\0x0AAllow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER\0x0D\0x0ASupported: x-sipura, replaces\0x0D\0x0AContent-Type: application/sdp\0x0D\0x0A\0x0D\0x0Av=0\0x0D\0x0Ao=- 5731440 5731440 IN IP4 192.168.1.86\0x0D\0x0As=-\0x0D\0x0Ac=IN IP4 192.168.1.86\0x0D\0x0At=0 0\0x0D\0x0Am=audio 16482 RTP/AVP 0 100 101\0x0D\0x0Aa=rtpmap:0 PCMU/8000\0x0D\0x0Aa=rtpmap:100 NSE/8000\0x0D\0x0Aa=fmtp:100 192-193\0x0D\0x0Aa=rtpmap:101 telephone-event/8000\0x0D\0x0Aa=fmtp:101 0-15\0x0D\0x0Aa=ptime:30\0x0D\0x0Aa=sendrecv192.168.1.86:5061>192.168.1.86>>192.168.1.86>
09/04/2013 20:54,Info,192.168.1.86,[0]<<127.0.0.1:5061(850)
09/04/2013 20:54,Debug,192.168.1.86,[1:0]AUD ALLOC CALL (port=16482)
09/04/2013 20:54,Debug,192.168.1.86,DLG Terminated 2e32d8
09/04/2013 20:54,Debug,192.168.1.86,ACK sip:+351289934899@127.0.0.1:5060 SIP/2.0\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-e82e15b4\0x0D\0x0AFrom: <192.168.1.86>;tag=ee29cdeda250e44co1\0x0D\0x0ATo: <>;tag=41a4673363daabc0i0\0x0D\0x0ACall-ID: 619bb341-90ce1f08@192.168.1.86\0x0D\0x0ACSeq: 101 ACK\0x0D\0x0AMax-Forwards: 70\0x0D\0x0AContact: <192.168.1.86:5061>\0x0D\0x0AUser-Agent: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86:5061>>192.168.1.86>
09/04/2013 20:54,Debug,192.168.1.86,DLG Terminated 2e2da4
09/04/2013 20:54,Debug,192.168.1.86,SIP/2.0 200 OK\0x0D\0x0ATo: <>;tag=41a4673363daabc0i0\0x0D\0x0AFrom: <192.168.1.86>;tag=ee29cdeda250e44co1\0x0D\0x0ACall-ID: 619bb341-90ce1f08@192.168.1.86\0x0D\0x0ACSeq: 101 CANCEL\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-e82e15b4\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86>>
09/04/2013 20:54,Debug,192.168.1.86,SIP/2.0 487 Request Terminated\0x0D\0x0ATo: <>;tag=41a4673363daabc0i0\0x0D\0x0AFrom: <192.168.1.86>;tag=ee29cdeda250e44co1\0x0D\0x0ACall-ID: 619bb341-90ce1f08@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-e82e15b4\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86>>
09/04/2013 20:54,Debug,192.168.1.86,CANCEL sip:+351289934899@127.0.0.1:5060 SIP/2.0\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-e82e15b4\0x0D\0x0AFrom: <192.168.1.86>;tag=ee29cdeda250e44co1\0x0D\0x0ATo: <>\0x0D\0x0ACall-ID: 619bb341-90ce1f08@192.168.1.86\0x0D\0x0ACSeq: 101 CANCEL\0x0D\0x0AMax-Forwards: 70\0x0D\0x0AUser-Agent: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0>192.168.1.86>
09/04/2013 20:54,Debug,192.168.1.86,FXO:CNDD Name= Phone=969622043
09/04/2013 20:54,Debug,192.168.1.86,FXO:CNDD name=, number=969622043
09/04/2013 20:54,Debug,192.168.1.86,-- Caller ID:\0x0A-- Name = (null)\0x0A-- Remote Number = 969622043\0x0A-- Dialable Number = (null)\0x0A-- No Number Reason = (null)\0x0A-- No Name Reason = (null)\0x0A-- Message Waiting = (null)\0x0A-- Date and Time = 04/09 20:54
09/04/2013 20:54,Debug,192.168.1.86,fxo cnddwrap_feed parse ok 969622043 status=2
09/04/2013 20:54,Debug,192.168.1.86,caller id parse number=969622043
09/04/2013 20:54,Debug,192.168.1.86,SIP/2.0 180 Ringing\0x0D\0x0ATo: <>;tag=41a4673363daabc0i0\0x0D\0x0AFrom: <192.168.1.86>;tag=ee29cdeda250e44co1\0x0D\0x0ACall-ID: 619bb341-90ce1f08@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-e82e15b4\0x0D\0x0AContact: +351289934899 <>\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0ARemote-Party-ID: +351289934899 <>>>192.168.1.86>>+351289934899@sip.freevoipdeal.com>;screen=yes;party=called\0x0D\0x0AContent-Length: 0
09/04/2013 20:54,Debug,192.168.1.86,[0:0]AUD ALLOC CALL (port=16480)
09/04/2013 20:54,Debug,192.168.1.86,SIP/2.0 100 Trying\0x0D\0x0ATo: <>\0x0D\0x0AFrom: <192.168.1.86>;tag=ee29cdeda250e44co1\0x0D\0x0ACall-ID: 619bb341-90ce1f08@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-e82e15b4\0x0D\0x0AServer: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 0192.168.1.86>>
09/04/2013 20:54,Debug,192.168.1.86,INVITE sip:+351289934899@127.0.0.1:5060 SIP/2.0\0x0D\0x0AVia: SIP/2.0/UDP 192.168.1.86:5061;branch=z9hG4bK-e82e15b4\0x0D\0x0AFrom: <192.168.1.86>;tag=ee29cdeda250e44co1\0x0D\0x0ATo: <>\0x0D\0x0ARemote-Party-ID: <192.168.1.86>;screen=yes;party=calling\0x0D\0x0AAlert-Info: Bellcore-r1\0x0D\0x0ACall-ID: 619bb341-90ce1f08@192.168.1.86\0x0D\0x0ACSeq: 101 INVITE\0x0D\0x0AMax-Forwards: 70\0x0D\0x0AContact: <192.168.1.86:5061>\0x0D\0x0AExpires: 240\0x0D\0x0AUser-Agent: Linksys/SPA3102-5.2.13(GW002)\0x0D\0x0AContent-Length: 255\0x0D\0x0AAllow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER\0x0D\0x0ASupported: x-sipura, replaces\0x0D\0x0AContent-Type: application/sdp\0x0D\0x0A\0x0D\0x0Av=0\0x0D\0x0Ao=- 5730006 5730006 IN IP4 192.168.1.86\0x0D\0x0As=-\0x0D\0x0Ac=IN IP4 192.168.1.86\0x0D\0x0At=0 0\0x0D\0x0Am=audio 16478 RTP/AVP 0 100 101\0x0D\0x0Aa=rtpmap:0 PCMU/8000\0x0D\0x0Aa=rtpmap:100 NSE/8000\0x0D\0x0Aa=fmtp:100 192-193\0x0D\0x0Aa=rtpmap:101 telephone-event/8000\0x0D\0x0Aa=fmtp:101 0-15\0x0D\0x0Aa=ptime:30\0x0D\0x0Aa=sendrecv192.168.1.86:5061>192.168.1.86>>192.168.1.86>
09/04/2013 20:54,Debug,192.168.1.86,[1:0]AUD ALLOC CALL (port=16478)
Any idea what might be going wrong here?
Thank you!
11-28-2013 10:48 AM
I have exactly the same problem with my SPA3102. Has anyone found the solution?
My logs:
https://dl.dropboxusercontent.com/u/24065517/syslog.514.log
https://dl.dropboxusercontent.com/u/24065517/syslog.514_2.log
11-11-2014 04:35 AM
Sorry to drag up an old thread... but I've just got my spa3102 out of mothballs & trying to get it going on a Portuguese telecom.pt line
I get this exact same problem & it's driving me nuts :)
Any help appreciated!
11-11-2014 12:29 PM
Well, at least I am not the only one with the problem!
But unfortunately, I never found a solution... tried lots of things, but no joy. Hopefully you'll have better luck!
11-12-2014 02:29 AM
Thanks for coming back to me.
The only ground I made was upgrading to the last release software 5.2.13 stops the repeated calls coming in every 3 seconds or so - you now just get the original call followed 3 rings later by what seems to be a voip call.
Strange behaviour that I think I'm going to have to admit defeat on...
Did you ever get any voip phone working successfully on the pt-meo line?
11-12-2014 04:35 AM
No problems whatsoever with the Gigaset IP series phones (e.g. Gigaset C470IP, C590IP, C610IP etc.). A much better experience... it's almost plug-and-go!
Also got a Fritzbox working, no major issues although it took a little more tinkering. Ultimately, the problem is specific to the SPA1302, haven't encountered that issue with any other VOIP equipment....
11-12-2014 09:01 AM
OK, thanks.
Although... after numerous hours!! I think I might have sorted it...
Voice PSTN Line - FXO Timer Values
PSTN Ring Timeout:
Portugal is fairly unusual in that the ring cadence is 1s on/5s off so the PSTN ring timeout needs to be 6s or more otherwise the spa thinks the call has stopped
03-27-2016 12:59 PM
Thank you Bandit9999. I can't thank you enough. This problem was driving me nuts for almost a month. Increasing the time out value solved the problem. Thank you so much. I made this account just to thank you :)
kxr
