238
Highlighted
Beginner
SPA8000 configuration help- dedicating phone number to particular line
I need to know how, or if its possible, to dedicate a phone number to only ring on one particular line. We purchased a block of 6 numbers from a VOIP service provider. I want to dedicate each of the numbers to only ring one of the SPA8000 lines. For example: we have been given numbers 555-0001 through 555-0006. I want 555-0001 ring on line 1 of the SPA8000, 555-0002 to only ring on line 2, etc. I don't need call forwarding, or any other features. By default, it appears that the SPA8000 is set up to ring line 1 first, no matter what number you dial. If that line is off hook than it goes to line 2-etc.
Any help would be much appreciated.
0 REPLIES 0
