03-04-2010 07:21 PM - edited 03-21-2019 09:24 AM
i just bought spa8800 series gateway 4fxs with 4 fxo port. And found there is no option to set NAT mapping enable "No" however does allow to set for Phone 1 but for other lines its "Yes" by default and does not allow to set.
We did try to disable by provisioning method:(using .cfg) Added NAT Mapping Enable "no" (parameter) under phone 1 2 3 but as soon as SPC tool compile .txt file to .cfg but it prompts error.
Any suggestion..............
03-05-2010 03:50 PM
Phone 2-4 and Line 2-4 is permanently natted by default. This is as designed.
03-07-2010 04:51 PM
Thank you for your reply.
Would it be posisble to explain what's the logic behind to designed this way ? where 1 port has option and other dont.
You may give me technical logic as i am CCIE, CCVP.
waiting for your response.
regards
03-08-2010 08:48 AM
On the 8800, phone 1 and line 1 are the only interfaces that lead directly out of the unit.
02-24-2011 05:33 PM
We have run into this issue as well. I am unable to get the 2, 3 or 4 ports to turn NAT Mapping OFF.
We purchased the 8800 in order to consolidate multiple lines into one box as suggested in some other Cisco forums (instead of purchasing multiple SPA3102's). This needs to be resolved. How can we get the NAT turned off??
