11-18-2017 09:00 AM - edited 03-21-2019 10:41 AM
Hi there,
I am looking for SPA122 users who may help me understand if that would fit my needs.
My home alarm system needs a standard analog line ... I have no anymore but VoIP instead ...
Would the box do the job ?
Many thanks !
11-18-2017 02:46 PM
I've got a home alarm and an SPA 122. The SPA 122 is registered to an Asterisk and goes out as a VoIP to my provider.
The difficult part is the setup but once that's done, it's all good.
Please don't forget to upgrade the firmware FIRST before starting with the configuration.
11-19-2017 01:44 AM
Thanks a lot ... so you have VoIP and no analog line, and have your SPA122 converting VoIP into analog then entering the alarm system ...
What alarm brand do you have ?
11-19-2017 02:05 AM
The SPA is to convert analogue to IP.
11-19-2017 02:46 AM
?? I though the opposite ... in case you had VoIP and yoy want to connect analog devices like phone, alarm system etc ...
11-19-2017 12:03 PM
That's what it is.
The Alarm system is analogue. The SPA converts the analogue to IP.
11-20-2017 12:13 AM
ok ... thanks a lot ... for me converting is having something and transforming to something else.
I have VoIP and I had in mind the box would transform the VoIP into Analog.
11-20-2017 12:49 PM
Be very careful. There's nothing like "standard analog line". Exact line voltage, impedance, ring signal voltage and/or shape - all those parameters vary from country to country and even between telco operators.
Other user experiences may not apply to you. Your alarm may be unable to work with SPA122. Make sure analog line parameters required by alarm in question are compatible with SPA122.
06-19-2018 09:20 AM
Hey fa35515;
I read your article about 2 weeks ago looking for an answer and I have been through about 20 different forums, support pages, everything! I was able to successfully get ..... now 3 Alarm lines fixed and operating off a Cisco SPA122 where as before my company did not previously offer that type of solution.
The secret Sauce within the Line settings on FW: Version 1.3.5 (004p)
Network Settings:
Network Jitter Level: Has worked on Both High/Extremely High
Jitter Buffer Adjustment: No
Audio Configuration:
DTMF Tx Method: Inband+INFO (default is Auto)
DTMF Tx Mode: Normal (default is Strict)
I've also read through posts about T38 needing to be enabled and have it working when enabled and disabled so i will go ahead and label that as a setting that's not needed on an ATA for an alarm line to work. Also want to note that echo Cancellation set to: Yes does not impact the alarm line operation but also saw that setting thrown around in some forums.
Again, i'm no alarm expert, SIP/VOIP engineer or even understand DTMF in it's entirety but these are the settings that worked for me.
Cheers,
RJ Maldonado
Network Technician
01-18-2020 07:48 AM
Thanks very much for posting the info, you helped me with a big headache.
02-14-2020 02:21 PM
Awesome @jdeschen - it definitely caused me a good month of headaches and testing! Glad it's still paying off for others, thanks for the Helpful badge - aka cisco street cred!
