04-11-2011 10:33 AM - edited 03-21-2019 09:35 AM
I have been trying to create a standard configuration for our voice service.
I backup the config.
Choose another router, restore config, the voice feature codes and/or settings are lost.
Am I doing something wrong?
I need to create a default config that I can load on each router and then customize with sip username/password authid etc.
Any help greatly appreciated.
Gilbert.
04-12-2011 11:11 AM
04-12-2011 11:16 AM
Hi Mr. Gilbert,
We have a perfect match for your need.
The WRP400 is fully provisioned via XML, where you can generate a XML file with all your desirable configuration and upload it to the equipment via TFTP, FTP, HTTP and HTTPS.
You can find in the link below a guide to previsions your WRP400.
I hope it help you.
Regards.
CISCO
Andrey Cassemiro
System Engineer SBTG
04-13-2011 09:35 AM
Hi Mr. Gilbert,
http://www.cisco.com/en/US/docs/voice_ip_comm/csbpvga/ata/provisioning/guide/Cisco_Small_Business_IP_Telephony_Provisioning_Guide.pdf
I hope it help you.
Regards.
CISCO
Andrey Cassemiro
55 11 5508 1544 | 55 11 9260 6339
Together we are the human network
