05-10-2012 11:50 AM - last edited on 03-25-2019 11:07 PM by ciscomoderator
Any one has tried to configure the WRP400 to using its FXS ports as SIP phone, with Microsoft Lync 2010 server?
Been trying to configure the WRP400 Line 1, got only failed registration, unable to get registered to the lync server thru sip (both under TCP and TLS)
During the registration attempt by the WRP 400, the analog phone attached did receive a ring, but after that it failed registration.
Anyone with more information or ideas are welcome and appreciated.
Darrell Tan
Solved! Go to Solution.
05-17-2012 09:09 AM
We need the full sip debug log.
In the ext/line tab, you would go to SIP settings, SIP debug option and set that to full.
In the system tab, make sure that debug level is set to 3.
The previous link https://supportforums.cisco.com/docs/DOC-9862
has links to the various models on how to set.
05-11-2012 10:19 AM
If the unit falis to register to the sip proxy, check the debug log to see why it's getting rejected.
Debug log info at
05-17-2012 08:11 AM
Hi Nestor,
Used the slogsvr, this is what I got.
Thu May 17 21:07:50 2012 SIP/TCP NewLocalPort:5060
Thu May 17 21:07:50 2012 SIP/TCP:Connecting(17)...
Thu May 17 21:07:50 2012 SIP/TCP:ConnErr:111
Thu May 17 21:07:50 2012 SIP/TCP:Connect=-1
Thu May 17 21:07:50 2012 SIP/TCP Backoff 1000 ms
Thu May 17 21:07:51 2012 SIP/TCP NewLocalPort:5061
Thu May 17 21:07:51 2012 SIP/TCP:Connecting(17)...
Thu May 17 21:07:51 2012 SIP/TCP:ConnErr:111
Thu May 17 21:07:51 2012 SIP/TCP:Connect=-1
Thu May 17 21:07:51 2012 SIP/TCP Backoff 2000 ms
Thu May 17 21:07:53 2012 SIP/TCP NewLocalPort:5060
Thu May 17 21:07:53 2012 SIP/TCP:Connecting(17)...
Thu May 17 21:07:53 2012 SIP/TCP:ConnErr:111
Thu May 17 21:07:53 2012 SIP/TCP:Connect=-1
Thu May 17 21:07:53 2012 SIP/TCP Backoff 4000 ms
Thu May 17 21:07:57 2012 SIP/TCP NewLocalPort:5061
Thu May 17 21:07:57 2012 SIP/TCP:Connecting(17)...
Thu May 17 21:07:57 2012 SIP/TCP:ConnErr:111
Thu May 17 21:07:57 2012 SIP/TCP:Connect=-1
Thu May 17 21:07:57 2012 SIP/TCP Backoff 8000 ms
Thu May 17 21:08:05 2012 SIP/TCP NewLocalPort:5060
Thu May 17 21:08:05 2012 SIP/TCP:Connecting(17)...
Thu May 17 21:08:05 2012 SIP/TCP:ConnErr:111
Thu May 17 21:08:05 2012 SIP/TCP:Connect=-1
Thu May 17 21:08:05 2012 SIP/TCP Backoff 16000 ms
Thu May 17 21:08:19 2012 SIP/TCP NewLocalPort:5061
Thu May 17 21:08:19 2012 SIP/TCP:Connecting(17)...
Thu May 17 21:08:19 2012 SIP/TCP:ConnErr:111
Thu May 17 21:08:19 2012 SIP/TCP:Connect=-1
Thu May 17 21:08:19 2012 SIP/TCP Backoff 500 ms
Thu May 17 21:08:19 2012 RegFail. Retry in 30
Thu May 17 21:08:19 2012 SIP/TCP Idle
Please note on my lync server the setting is listening TCP 5061
On my WRP SIP/TCP 5061.
05-17-2012 09:09 AM
05-17-2012 12:56 PM
Hi nseto,
I have again reconfigure everything. The WRP400 is set to only look at port 5060, and the same I set in the lync server. More over the topology now points to only the WRP400. In my DNS I have also include the DNS SVR records for both devices for siptcp:5060
After some creative configuration, the lync server does not report any issues in contact the ATA gateway (WRP400).
I am unable to attached the file. Please accept my apologies in this post.
What I now see is the sip NOTIFY and REGISTER. But it still fail to register the device to lync.
If you could, help me understand which sequence fail to respond and which device fail to register.
The text log starts ++++++++
syslog server(port:514) started on Fri May 18 03:30:54 2012
Fri May 18 03:31:18 2012 syslogd started: Busybox v1.00 kernel: klogd started: Busybox v1.00 kernel: Linux version 2.6.16.16-88w8xx8 (u99040@ubuntu) (gcc version 3.4.6) #1 PREEMPT Fri Jan 28 14:45:44 CST 2011 kernel: CPU: ARM926EJ-Sid(wb) revision 0 (ARMv5TEJ) kernel: Machine: MV88W8518 kernel: Using U-Boot passing parameters structure - U-Boot release 1.1.1.5 kernel: Memory policy: ECC disabled, Data cache writeback kernel: On node 0 totalpages: 8192 kernel: DMA zone: 8192 pages, LIFO batch:1 kernel: DMA32 zone: 0 pages, LIFO batch:0 kernel: Normal zone: 0 pages, LIFO batch:0 kernel: HighMem zone: 0 pages, LIFO batch:0 kernel: CPU0: D VIVT write-back cache kernel: CPU0: I cache: 32768 bytes, associativity 1, 32 byte lines, 1024 sets kernel: CPU0: D cache: 32768 bytes, associativity 4, 32 byte lines, 256 sets kernel: Built 1 zonelists kernel: Kernel command line: console=ttyS0,115200 root=/dev/mtdblock0 ro noinitrd ip=192.168.15.1:192.168.15.111:::MV88W8518:eth0:none console_state=locked cy_flash_size=0x800000 cy_flash_block_size=0x10000 full_image_addr=ff9c0000 half_image_addr=ff800000 boot_image=1 kernel: PID hash table entries: 256 (order: 8, 4096 bytes) kernel: Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) kernel: Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) kernel: Memory: 32MB = 32MB total kernel: Memory: 30208KB available (1780K code, 322K data, 76K init) kernel: Calibrating delay loop... 368.64 BogoMIPS (lpj=1843200) kernel: Mount-cache hash table entries: 512 kernel: CPU: Testing write buffer coherency: ok kernel: NET: Registered protocol family 16 kernel: MV88W8XX8 LSP release 11 for kernel 2.6.16.16 kernel: Marvell USB EHCI Host controller kernel: Marvell USB Gadget device controller kernel: TC classifier action (bugs to netdev@vger.kernel.org cc hadi@cyberus.ca) kernel: squashfs: version 3.1 (2006/08/19) Phillip Lougher kernel: we use LZMA workspace is 15980, and original zlib ws is 46912 kernel: Initializing Cryptographic API kernel: io scheduler noop registered kernel: io scheduler deadline registered (default) kernel: HDLC line discipline: version $Revision: 4.8 $, maxframe=4096 kernel: N_HDLC line discipline registered. kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing enabled kernel: serial8250: ttyS0 at MMIO 0xf800c840 (irq = 11) is a 16550 kernel: PPP generic driver version 2.4.2 kernel: PPP MPPE Compression module registered kernel: NET: Registered protocol family 24 kernel: PHY found at addr 16, ID 1410c89, mii_status 78c9 kernel: eth0: mv88w8xx8 FEC @ 80008000, 00:09:11:22:33:45 irq 9 kernel: eth1: mv88w8xx8 FEC @ 80008000, 00:09:11:22:33:46 irq 9 kernel: QD_REG_PVID[18] = 2 kernel: QD_REG_PORT_VLAN_MAP[18] = 1020 kernel: QD_REG_PORT_CONTROL[18] = 7f kernel: QD_REG_RATE_CONTROL[18] = c000 kernel: QD_REG_PVID[19] = 1 kernel: QD_REG_PORT_VLAN_MAP[19] = 3c kernel: QD_REG_PORT_CONTROL[19] = 47f kernel: QD_REG_RATE_CONTROL[19] = c000 cron[260]: (CRON) STARTUP (fork ok) kernel: QD_REG_PVID[1a] = 1 kernel: QD_REG_PORT_VLAN_MAP[1a] = 3a kernel: QD_REG_PORT_CONTROL[1a] = 47f kernel: QD_REG_RATE_CONTROL[1a] = c000 kernel: QD_REG_PVID[1b] = 1 kernel: QD_REG_PORT_VLAN_MAP[1b] = 36 kernel: QD_REG_PORT_CONTROL[1b] = 47f kernel: QD_REG_RATE_CONTROL[1b] = c000 kernel: QD_REG_PVID[1c] = 1 kernel: QD_REG_PORT_VLAN_MAP[1c] = 2e kernel: QD_REG_PORT_CONTROL[1c] = 47f kernel: QD_REG_RATE_CONTROL[1c] = c000 kernel: QD_REG_PVID[1d] = 1 kernel: QD_REG_PORT_VLAN_MAP[1d] = 1f kernel: QD_REG_PORT_CONTROL[1d] = 87f kernel: QD_REG_RATE_CONTROL[1d] = c000 kernel: QD_REG_GLOBAL_CONTROL = 1 kernel: full_image_addr kernel: half_image_addr kernel: boot_image kernel: k_size= 000f86d0 kernel: f_size= 002e0000 kernel: pad k_size= 000f86d0 kernel: p_size=c2a4004c,p_base_addr=c2a40000 kernel: fs_offset= 000f871c kernel: mv88w8xx8 flash: Found 1 x16 devices at 0x0 in 16-bit bank kernel: Amd/Fujitsu Extended Query Table at 0x0040 kernel: number of CFI chips: 1 kernel: cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness. kernel: Creating 8 MTD partitions on "mv88w8xx8 flash": kernel: 0x002b871c-0x006e0000 : "LINUX_ROOTFS" kernel: mtd: partition "LINUX_ROOTFS" doesn't start on an erase block boundary -- force read-only kernel: 0x00000000-0x001c0000 : "HALFIMAGE" kernel: 0x001c0000-0x006e0000 : "ROMIMAGE" kernel: 0x006e0000-0x00720000 : "FPAR" kernel: 0x00720000-0x00760000 : "LANG" kernel: 0x00760000-0x00780000 : "MFG_DATA" kernel: 0x00780000-0x007a0000 : "NVRAM" kernel: 0x007a0000-0x00800000 : "UBOOT" kernel: Linux telephony interface: v1.00 kernel: tdu_init() kernel: ++++++++ tdu_device_init kernel: enable Daisy Chain kernel: slicConfigure() reading 83 from slic 0 devId 1 kernel: Read Si3215 Revision H on slic 0 kernel: Direct read/write test passed on slic 0 kernel: Indirect read/write test passed on slic 0 kernel: Entering SLIC DC Power Calibration check ......Passed kernel: Entering SLIC Calibration check................Passed kernel: slicConfigure: Setting CODEC on slic 0 to linear 16-bit mode kernel: SLIC 0 PCM settings: txCountLow 1, txCountHi 0 kernel: SLIC 0 PCM settings: rxCountLow 1, rxCountHi 0 kernel: #########REGISTER DUMP FOR SLIC 0 ######### kernel: Direct Register 0: 0x83 kernel: Direct Register 1: 0xbc kernel: Direct Register 2: 0x01 kernel: Direct Register 3: 0x00 kernel: Direct Register 4: 0x01 kernel: Direct Register 5: 0x00 kernel: Direct Register 6: 0x00 kernel: Direct Register 7: 0x00 kernel: Direct Register 8: 0x00 kernel: Direct Register 9: 0x00 kernel: Direct Register 10: 0x08 kernel: Direct Register 11: 0x33 kernel: Direct Register 14: 0x00 kernel: Direct Register 15: 0x00 kernel: Direct Register 18: 0x00 kernel: Direct Register 19: 0x00 kernel: Direct Register 20: 0x00 kernel: Direct Register 21: 0x00 kernel: Direct Register 22: 0x00 kernel: Direct Register 23: 0x00 kernel: Direct Register 28: 0x00 kernel: Direct Register 29: 0x0c kernel: Direct Register 30: 0x40 kernel: Direct Register 31: 0x00 kernel: Direct Register 32: 0x00 kernel: Direct Register 33: 0x00 kernel: Direct Register 34: 0x00 kernel: Direct Register 35: 0x00 kernel: Direct Register 36: 0x00 kernel: Direct Register 37: 0x00 kernel: Direct Register 38: 0x00 kernel: Direct Register 39: 0x00 kernel: Direct Register 40: 0x00 kernel: Direct Register 41: 0x00 kernel: Direct Register 42: 0x00 kernel: Direct Register 43: 0x00 kernel: Direct Register 44: 0x00 kernel: Direct Register 45: 0x00 kernel: Direct Register 46: 0x00 kernel: Direct Register 47: 0x00 kernel: Direct Register 48: 0x00 kernel: Direct Register 49: 0x00 kernel: Direct Register 50: 0x00 kernel: Direct Register 51: 0x00 kernel: Direct Register 52: 0x00 kernel: Direct Register 63: 0x54 kernel: Direct Register 64: 0x00 kernel: Direct Register 65: 0x61 kernel: Direct Register 66: 0x03 kernel: Direct Register 67: 0x1f kernel: Direct Register 68: 0x04 kernel: Direct Register 69: 0x10 kernel: Direct Register 70: 0x10 kernel: Direct Register 71: 0x00 kernel: Direct Register 72: 0x20 kernel: Direct Register 73: 0x04 kernel: Direct Register 74: 0x32 kernel: Direct Register 75: 0x10 kernel: Direct Register 76: 0x00 kernel: Direct Register 77: 0x00 kernel: Direct Register 78: 0x00 kernel: Direct Register 79: 0x00 kernel: Direct Register 80: 0x00 kernel: Direct Register 81: 0x00 kernel: Direct Register 82: 0xc8 kernel: Direct Register 83: 0xc8 kernel: Direct Register 84: 0x00 kernel: Direct Register 85: 0x01 kernel: Direct Register 86: 0x00 kernel: Direct Register 87: 0x00 kernel: Direct Register 88: 0x03 kernel: Direct Register 89: 0x00 kernel: Direct Register 92: 0xc8 kernel: Direct Register 93: 0x19 kernel: Direct Register 94: 0x2b kernel: Direct Register 95: 0x01 kernel: Direct Register 96: 0x00 kernel: Direct Register 97: 0x00 kernel: Direct Register 98: 0x11 kernel: Direct Register 99: 0x12 kernel: Direct Register 100: 0x11 kernel: Direct Register 101: 0x11 kernel: Direct Register 102: 0x08 kernel: Direct Register 103: 0x38 kernel: Direct Register 104: 0x00 kernel: Direct Register 105: 0x00 kernel: Direct Register 106: 0x20 kernel: Direct Register 107: 0x00 kernel: Direct Register 108: 0x00 kernel: Indirect Register 0: 0x5a82 kernel: Indirect Register 1: 0x0d42 kernel: Indirect Register 2: 0x0000 kernel: Indirect Register 3: 0x4a80 kernel: Indirect Register 4: 0x0830 kernel: Indirect Register 5: 0x0000 kernel: Indirect Register 6: 0x0000 kernel: Indirect Register 7: 0x7efd kernel: Indirect Register 8: 0x0180 kernel: Indirect Register 9: 0x0000 kernel: Indirect Register 10: 0xc118 kernel: Indirect Register 11: 0x23f4 kernel: Indirect Register 12: 0xbfcf kernel: Indirect Register 13: 0x4800 kernel: Indirect Register 14: 0x6000 kernel: Indirect Register 15: 0x1000 kernel: Indirect Register 16: 0x3600 kernel: Indirect Register 17: 0x1000 kernel: Indirect Register 18: 0x0200 kernel: Indirect Register 19: 0x1000 kernel: Indirect Register 20: 0x376f kernel: Indirect Register 21: 0x1000 kernel: Indirect Register 22: 0x8000 kernel: : 0x0320 kernel: Indirect Register 24: 0x008c kernel: Indirect Register 25: 0x0010 kernel: Indirect Register 26: 0x008c kernel: Indirect Register 27: 0x0000 kernel: Indirect Register 64: 0x0c00 kernel: Indirect Register 66: 0x1000 kernel: Indirect Register 69: 0x774f kernel: Indirect Register 70: 0xcecf kernel: Indirect Register 71: 0x6dfd kernel: Indirect Register 72: 0xa0cf kernel: Indirect Register 73: 0xb7f5 kernel: Indirect Register 74: 0xd9e7 kernel: #########REGISTER DUMP END######### kernel: kernel: #### Si3215Mode control; mode=1 kernel: slicConfigure() reading 83 from slic 1 devId 2 kernel: Read Si3215 Revision H on slic 1 kernel: Direct read/write test passed on slic 1 kernel: Indirect read/write test passed on slic 1 kernel: Entering SLIC DC Power Calibration check ......Passed kernel: Entering SLIC Calibration check................Passed kernel: slicConfigure: Setting CODEC on slic 1 to linear 16-bit mode kernel: SLIC 1 PCM settings: txCountLow 33, txCountHi 0 kernel: SLIC 1 PCM settings: rxCountLow 33, rxCountHi 0 kernel: #########REGISTER DUMP FOR SLIC 1 ######### kernel: Direct Register 0: 0x83 kernel: Direct Register 1: 0xbc kernel: Direct Register 2: 0x21 kernel: Direct Register 3: 0x00 kernel: Direct Register 4: 0x21 kernel: Direct Register 5: 0x00 kernel: Direct Register 6: 0x00 kernel: Direct Register 7: 0x00 kernel: Direct Register 8: 0x00 kernel: Direct Register 9: 0x00 kernel: Direct Register 10: 0x08 kernel: Direct Register 11: 0x33 kernel: Direct Register 14: 0x00 kernel: Direct Register 15: 0x00 kernel: Direct Register 18: 0x00 kernel: Direct Register 19: 0x00 kernel: Direct Register 20: 0x00 kernel: Direct Register 21: 0x00 kernel: Direct Register 22: 0x00 kernel: Direct Register 23: 0x00 kernel: Direct Register 28: 0x00 kernel: Direct Register 29: 0x0c kernel: Direct Register 30: 0x40 kernel: Direct Register 31: 0x00 kernel: Direct Register 32: 0x00 kernel: Direct Register 33: 0x00 kernel: Direct Register 34: 0x00 kernel: Direct Register 35: 0x00 kernel: Direct Register 36: 0x00 kernel: Direct Register 37: 0x00 kernel: Direct Register 38: 0x00 kernel: Direct Register 39: 0x00 kernel: Direct Register 40: 0x00 kernel: Direct Register 41: 0x00 kernel: Direct Register 42: 0x00 kernel: Direct Register 43: 0x00 kernel: Direct Register 44: 0x00 kernel: Direct Register 45: 0x00 kernel: Direct Register 46: 0x00 kernel: Direct Register 47: 0x00 kernel: Direct Register 48: 0x00 kernel: Direct Register 49: 0x00 kernel: Direct Register 50: 0x00 kernel: Direct Register 51: 0x00 kernel: Direct Register 52: 0x00 kernel: Direct Register 63: 0x54 kernel: Direct Register 64: 0x00 kernel: Direct Register 65: 0x61 kernel: Direct Register 66: 0x03 kernel: Direct Register 67: 0x1f kernel: Direct Register 68: 0x04 kernel: Direct Register 69: 0x10 kernel: Direct Register 70: 0x10 kernel: Direct Register 71: 0x00 kernel: Direct Register 72: 0x20 kernel: Direct Register 73: 0x04 kernel: Direct Register 74: 0x32 kernel: Direct Register 75: 0x10 kernel: Direct Register 76: 0x00 kernel: Direct Register 77: 0x00 kernel: Direct Register 78: 0x00 kernel: Direct Register 79: 0x40 kernel: Direct Register 80: 0x00 kernel: Direct Register 81: 0x00 kernel: Direct Register 82: 0xc6 kernel: Direct Register 83: 0xc6 kernel: Direct Register 84: 0x01 kernel: Direct Register 85: 0x01 kernel: Direct Register 86: 0x00 kernel: Direct Register 87: 0x00 kernel: Direct Register 88: 0x00 kernel: Direct Register 89: 0x03 kernel: Direct Register 92: 0xc8 kernel: Direct Register 93: 0x19 kernel: Direct Register 94: 0x2d kernel: Direct Register 95: 0x01 kernel: Direct Register 96: 0x00 kernel: Direct Register 97: 0x00 kernel: Direct Register 98: 0x10 kernel: Direct Register 99: 0x11 kernel: Direct Register 100: 0x11 kernel: Direct Register 101: 0x11 kernel: Direct Register 102: 0x08 kernel: Direct Register 103: 0x00 kernel: Direct Register 104: 0x00 kernel: Direct Register 105: 0x00 kernel: Direct Register 106: 0x20 kernel: Direct Register 107: 0x00 kernel: Direct Register 108: 0x00 kernel: Indirect Register 0: 0x5a82 kernel: Indirect Register 1: 0x0d42 kernel: Indirect Register 2: 0x0000 kernel: Indirect Register 3: 0x4a80 kernel: Indirect Register 4: 0x0830 kernel: Indirect Register 5: 0x0000 kernel: Indirect Register 6: 0x0000 kernel: Indirect Register 7: 0x7efd kernel: Indirect Register 8: 0x0180 kernel: 9: 0x0000 kernel: Indirect Register 10: 0xb4fb kernel: Indirect Register 11: 0x04a7 kernel: Indirect Register 12: 0xde13 kernel: Indirect Register 13: 0x4800 kernel: Indirect Register 14: 0x6000 kernel: Indirect Register 15: 0x1000 kernel: Indirect Register 16: 0x3600 kernel: Indirect Register 17: 0x1000 kernel: Indirect Register 18: 0x0200 kernel: Indirect Register 19: 0x1000 kernel: Indirect Register 20: 0x376f kernel: Indirect Register 21: 0x1000 kernel: Indirect Register 22: 0x8000 kernel: Indirect Register 23: 0x0320 kernel: Indirect Register 24: 0x008c kernel: Indirect Register 25: 0x0010 kernel: Indirect Register 26: 0x008c kernel: Indirect Register 27: 0x0000 kernel: Indirect Register 64: 0x0c00 kernel: Indirect Register 66: 0x1000 kernel: Indirect Register 69: 0xddb7 kernel: Indirect Register 70: 0xfcd7 kernel: Indirect Register 71: 0xf9aa kernel: Indirect Register 72: 0xd48a kernel: Indirect Register 73: 0xe57f kernel: Indirect Register 74: 0xf78d kernel: #########REGISTER DUMP END######### kernel: kernel: #### Si3215Mode control; mode=1 kernel: phone_mrvl: initialized kernel: GACT probability on kernel: Mirror/redirect action on kernel: u32 classifier kernel: Perfomance counters on kernel: input device check on kernel: Actions configured kernel: Netfilter messages via NETLINK v0.30. kernel: NET: Registered protocol family 2 kernel: IP route cache hash table entries: 512 (order: -1, 2048 bytes) kernel: TCP established hash table entries: 2048 (order: 1, 8192 bytes) kernel: TCP bind hash table entries: 2048 (order: 1, 8192 bytes) kernel: TCP: Hash tables configured (established 2048 bind 2048) kernel: TCP reno registered kernel: GRE over IPv4 tunneling driver kernel: ip_conntrack version 2.4 (256 buckets, 2048 max) - 220 bytes per conntrack kernel: ctnetlink v0.90: registering with nfnetlink. kernel: ip_conntrack_pptp version 3.1 loaded kernel: ip_nat_pptp version 3.0 loaded kernel: ip_tables: (C) 2000-2006 Netfilter Core Team kernel: TCP bic registered kernel: NET: Registered protocol family 1 kernel: NET: Registered protocol family 17 kernel: Bridge firewalling registered kernel: 802.1Q VLAN Support v1.8 Ben Greear kernel: br0: topology change detected, propagating kernel: br0: port 2(wlan0) entering forwarding state pppoe-relay[340]: recv (receivePacket): Network is down pppoe-relay[340]: recv (receivePacket): Network is downIDBG: LS, 260-53a
Fri May 18 03:31:35 2012 IDBG: SOK
Fri May 18 03:31:35 2012 IDBG: st-0
Fri May 18 03:31:35 2012 SIP/TCP Idle
Fri May 18 03:31:45 2012 ->192.168.18.20:5060(447)
Fri May 18 03:31:45 2012 NOTIFY sip:192.168.18.20 SIP/2.0v: SIP/2.0/TCP 0.0.0.0:5060;branch=z9hG4bK-419dcb99f: "Darrell Tan"
Fri May 18 03:31:50 2012 fs:007864:011974:065536
Fri May 18 03:31:50 2012 fbr:0:3000:3000:00dce1:0002:0001:2.00.26
Fri May 18 03:31:50 2012 -
eval_prov_logic 1 -
0 -- 2821
Fri May 18 03:31:50 2012 fu:0:0dcf3, 0003 0001
Fri May 18 03:31:53 2012 -
eval_prov_logic 1 -
1 -- 3031
Fri May 18 03:31:55 2012 -
eval_prov_logic 1 -
2 -- 3238
Fri May 18 03:31:57 2012 -
eval_prov_logic 1 -
3 -- 3445
Fri May 18 03:31:59 2012 -
eval_prov_logic 1 -
4 -- 3652
Fri May 18 03:32:01 2012 -
eval_prov_logic 1 -
5 -- 3859
Fri May 18 03:32:03 2012 -
eval_prov_logic 1 -
6 -- 4075
Fri May 18 03:32:05 2012 -
eval_prov_logic 1 -
7 -- 4282
Fri May 18 03:32:07 2012 -
eval_prov_logic 1 -
8 -- 4489
Fri May 18 03:32:09 2012 -
eval_prov_logic 1 -
9 -- 4696
Fri May 18 03:32:10 2012 ->192.168.18.20:5060(592)
Fri May 18 03:32:10 2012 REGISTER sip:jedavoice.dyndns.org SIP/2.0v: SIP/2.0/TCP 0.0.0.0:5060;branch=z9hG4bK-b997c693f: "Darrell Tan"
Fri May 18 03:32:11 2012 <<192.168.18.20:5060(346)
Fri May 18 03:32:11 2012 SIP/2.0 480 Temporarily UnavailableFROM: "Darrell Tan"
Fri May 18 03:32:11 2012 RegFail. Retry in 40
Fri May 18 03:32:17 2012 SIP/TCP Idle
Fri May 18 03:32:32 2012 ->192.168.18.20:5060(447)
Fri May 18 03:32:32 2012 NOTIFY sip:192.168.18.20 SIP/2.0v: SIP/2.0/TCP 0.0.0.0:5060;branch=z9hG4bK-7903c47bf: "Darrell Tan"
Fri May 18 03:32:33 2012 -
eval_prov_logic 1 -
10 -- 7099
Fri May 18 03:32:35 2012 -
eval_prov_logic 1 -
11 -- 7306
Fri May 18 03:32:35 2012 PRV ec=1
Fri May 18 03:32:37 2012 -
eval_prov_logic 1 -
12 -- 7513
Fri May 18 03:32:39 2012 -
eval_prov_logic 1 -
13 -- 7711
Fri May 18 03:32:50 2012 ->192.168.18.20:5060(592)
Fri May 18 03:32:50 2012 REGISTER sip:jedavoice.dyndns.org SIP/2.0v: SIP/2.0/TCP 0.0.0.0:5060;branch=z9hG4bK-5a2662bdf: "Darrell Tan"
Fri May 18 03:32:51 2012
Fri May 18 03:32:51 2012 <<192.168.18.20:5060(346)
Fri May 18 03:32:51 2012 SIP/2.0 480 Temporarily UnavailableFROM: "Darrell Tan"
Fri May 18 03:32:51 2012 RegFail. Retry in 40
Fri May 18 03:33:03 2012 -
eval_prov_logic 1 -
14 -- 10123
Fri May 18 03:33:04 2012 SIP/TCP Idle
Fri May 18 03:33:05 2012 -
eval_prov_logic 1 -
15 -- 10321
Fri May 18 03:33:05 2012 PRV ec=2
Fri May 18 03:33:07 2012 cron[342]: (root) CMD (/sbin/check_ps) -
eval_prov_logic 1 -
16 -- 10528
Fri May 18 03:33:10 2012 -
eval_prov_logic 1 -
17 -- 10735
Fri May 18 03:33:19 2012 ->192.168.18.20:5060(447)
Fri May 18 03:33:19 2012 NOTIFY sip:192.168.18.20 SIP/2.0v: SIP/2.0/TCP 0.0.0.0:5060;branch=z9hG4bK-cfce3fe5f: "Darrell Tan"
Fri May 18 03:33:31 2012 ->192.168.18.20:5060(592)
Fri May 18 03:33:31 2012 REGISTER sip:jedavoice.dyndns.org SIP/2.0v: SIP/2.0/TCP 0.0.0.0:5060;branch=z9hG4bK-d8f31dfff: "Darrell Tan"
Fri May 18 03:33:31 2012 <<192.168.18.20:5060(345)
Fri May 18 03:33:31 2012 SIP/2.0 480 Temporarily UnavailableFROM: "Darrell Tan"
Fri May 18 03:33:31 2012 RegFail. Retry in 40
Fri May 18 03:33:34 2012 -
eval_prov_logic 1 -
18 -- 13138
Fri May 18 03:33:36 2012 -
eval_prov_logic 1 -
19 -- 13345
Fri May 18 03:33:36 2012 PRV ec=3
Fri May 18 03:33:38 2012 -
eval_prov_logic 1 -
20 -- 13552
Fri May 18 03:33:40 2012 -
eval_prov_logic 1 -
21 -- 13750
Fri May 18 03:33:51 2012 SIP/TCP Idle
Fri May 18 03:34:04 2012 -
eval_prov_logic 1 -
22 -- 16162
Fri May 18 03:34:06 2012 -
eval_prov_logic 1 -
23 -- 16360
Fri May 18 03:34:06 2012 PRV ec=4
Fri May 18 03:34:06 2012 ->192.168.18.20:5060(447)
Fri May 18 03:34:06 2012 NOTIFY sip:192.168.18.20 SIP/2.0v: SIP/2.0/TCP 0.0.0.0:5060;branch=z9hG4bK-40c8c227f: "Darrell Tan"
Fri May 18 03:34:08 2012 -
eval_prov_logic 1 -
24 -- 16576
+++++++++++ text log end.
Thanks in advance.
Darrell Tan
05-17-2012 01:30 PM
The register and notify from the unit shows the ip address as 0.0.0.0. This needs to be corrected. Is the unit supposed to be using DHCP? It's not getting ip address?
05-17-2012 02:18 PM
Hi nseto,
In fact all devices are static ip. Sorry but I am not exactly as technically savvy, is that extraction for 0.0.0.0 ip address coming from the lync server or the WRP? If it's from the WRP, where do i set that device IP? I thought the wireless router had already an assignment, oris it a special field in the voice configuration side?
Thanks in advance.
Darrell Tan
05-17-2012 03:09 PM
From the register and notify, it shows
The ip address config should be in the setup menu.
05-17-2012 08:46 PM
Hi nseto,
Sorry, where would that be the setup?
Darrell Tan
05-18-2012 09:31 PM
Hi nseto,
I was unable to locate where to change that 0.0.0.0 ip address, is there a configuration tool?
I dont understand how to you the WRP400 SPC tool, is there a documentation which teaches me to use it?
Darrell Tam
05-21-2012 12:58 AM
Hi nseto,
I have new logs after some more configuration. ( Attached below )
Before connecting WAN:
++++Extract of Log +++
on May 21 12:42:36 2012 [0]->192.168.18.20:5060(553)
Mon May 21 12:42:36 2012 [0]->192.168.18.20:5060(553)
Mon May 21 12:42:36 2012 REGISTER sip:jedavoice.dyndns.org SIP/2.0
v: SIP/2.0/TCP 0.0.0.0:5061;branch=z9hG4bK-3705d748
f: "Darrell Tan" <>>Darrell.Tan@jedavoice.dyndns.org>;tag=58b22e34d6a3bc5fo0
t: "Darrell Tan" <>>Darrell.Tan@jedavoice.dyndns.org>
CSeq: 52261 REGISTER
Max-Forwards: 70
m: "Darrell Tan"
User-Agent: Linksys/WRP400-2.00.26
Proxy-Require: 192.168.18.18
l: 0
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, PRACK, REFER
k: 100rel, x-sipura, replaces
Max-Forwards: 70
m: "Darrell Tan"
l: 0
Mon May 21 12:42:36 2012 [0]<<192.168.18.20:5060(346)
Mon May 21 12:42:36 2012 SIP/2.0 480 Temporarily Unavailable
FROM: "Darrell Tan"<>>Darrell.Tan@jedavoice.dyndns.org>;tag=58b22e34d6a3bc5fo0
TO: "Darrell Tan"<>>Darrell.Tan@jedavoice.dyndns.org>;tag=a148ba5325
CSEQ: 52261 REGISTER
CALL-ID: cc3c7cfa-7a54a64@0.0.0.0
VIA: SIP/2.0/TCP 0.0.0.0:5061;branch=z9hG4bK-3705d748
CONTENT-LENGTH: 0
SERVER: RTCC/4.0.0.0
Mon May 21 12:42:36 2012 [0]RegFail. Retry in 45
++++ End of Extract++++++++
After connecting to a WAN
Mon May 21 15:35:02 2012 [0]->192.168.18.20:5060(580)
Mon May 21 15:35:02 2012 REGISTER sip:jedavoice.dyndns.org SIP/2.0
v: SIP/2.0/TCP 192.168.18.20:5060;branch=z9hG4bK-25913c93
f: "Darrell Tan" <>>Darrell.Tan@jedavoice.dyndns.org>;tag=a2743c33266d6d09o0
i: 95fed668-345a0fa4@10.241.239.152
CSeq: 51097 REGISTER
Max-Forwards: 70
m: "Darrell Tan"
Proxy-Require: jedavoice.dyndns.org
l: 0
Max-Forwards: 70
m: "Darrell Tan"
l: 0
Mon May 21 15:35:02 2012 [0]<<192.168.18.20:5060(360)
Mon May 21 15:35:02 2012 SIP/2.0 480 Temporarily Unavailable
FROM: "Darrell Tan"<>>Darrell.Tan@jedavoice.dyndns.org>;tag=a2743c33266d6d09o0
TO: "Darrell Tan"<>>Darrell.Tan@jedavoice.dyndns.org>;tag=e9154bf662
CSEQ: 51097 REGISTER
CALL-ID: 95fed668-345a0fa4@10.241.239.152
VIA: SIP/2.0/TCP 192.168.18.20:5060;branch=z9hG4bK-25913c93
CONTENT-LENGTH: 0
Mon May 21 15:35:02 2012 [0]RegFail. Retry in 45
However it does not change the outcome for registeration( which still fails) for the ATA (WRP400) to the Lync Server, I seen that the Lync had stop having issues of not seeing the ATA Gateway, and the log show the challenge for invite to the ATA Gateway.
Please advice.
Darrell Tan
05-21-2012 09:07 AM
It looks like the 0.0.0.0 is the issue. Force a static ip address in the wrp400 if it can't get an dhcp address. If you don't know how to do this, you'll need to contact the support center for assistance. Reference http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Thank you.
05-22-2012 03:49 PM
Hi nseto,
Thanks for the assistance earlier. Just to update you.
The earlier 0.0.0.0 IP was without an external WAN connection. if you connected without NAT Mapping in the Voice Admin, you wil get the External WAN IP address. If you connected to your WAN with NAT (VOICE), it will assume the IP address of the Router.
Now, I have come to almost wit's end on the WRP400
I finally able to configure all the components in the Lync Server to basic take the WRP400 as ATA gatgeway, however I keep getting the server responding that the WRP400 is not hailing back an SIP OPTIONS response.
I am attaching the newest logs which do show the SIP messages going from WRP 400 to Lync, and when Lync ask for SIP OPTION, the WRP400 does not respond.
+++++++Log of SIP Messages+++++
Wed May 23 06:11:03 2012
Wed May 23 06:11:05 2012 ---- eval_prov_logic 1 ---- 120 -- 94908
Wed May 23 06:11:07 2012 ---- eval_prov_logic 1 ---- 121 -- 95106
Wed May 23 06:11:07 2012 PRV ec=32
Wed May 23 06:11:09 2012 ---- eval_prov_logic 1 ---- 122 -- 95313
Wed May 23 06:11:11 2012 ---- eval_prov_logic 1 ---- 123 -- 95511
Wed May 23 06:11:12 2012 [0]SIP/TCP Idle
Wed May 23 06:11:20 2012 [0]->192.168.18.20:5066(608)
Wed May 23 06:11:20 2012 REGISTER sip:jedavoice.dyndns.org SIP/2.0
v: SIP/2.0/TCP 192.168.18.1:5066;branch=z9hG4bK-540475c0;rport
f: "Darrell Tan" <>>65300800@jedavoice.dyndns.org>;tag=b1700124c08e84d7o0
t: "Darrell Tan" <>>65300800@jedavoice.dyndns.org>
i: 797afee8-ec980104@10.223.117.252
CSeq: 34239 REGISTER
Max-Forwards: 70
m: "Darrell Tan" <65300800>;expires=360065300800>
Proxy-Require: 192.168.18.20
GUID: a006e699bfbda18bbe0cde68e4dcede6
l: 0
Wed May 23 06:11:21 2012 [0]<<192.168.18.20:5066(359)
Wed May 23 06:11:21 2012 SIP/2.0 480 Temporarily Unavailable
FROM: "Darrell Tan"<>>65300800@jedavoice.dyndns.org>;tag=b1700124c08e84d7o0
TO: "Darrell Tan"<>>65300800@jedavoice.dyndns.org>;tag=b5e35b6c5b
CSEQ: 34239 REGISTER
CALL-ID: 797afee8-ec980104@10.223.117.252
VIA: SIP/2.0/TCP 192.168.18.1:5066;branch=z9hG4bK-540475c0;rport
CONTENT-LENGTH: 0
Wed May 23 06:11:21 2012 [0]RegFail. Retry in 30
Wed May 23 06:11:26 2012 [0]SIP/TCP Idle
Wed May 23 06:11:27 2012 [0]->192.168.18.20:5066(475)
Wed May 23 06:11:27 2012 NOTIFY sip:192.168.18.20:5066 SIP/2.0
v: SIP/2.0/TCP 192.168.18.1:5066;branch=z9hG4bK-5c76b2eb;rport
t: <192.168.18.20:5066>192.168.18.20:5066>
i: 8b4cde19-ca2fc467@10.223.117.252
CSeq: 77 NOTIFY
Max-Forwards: 70
m: "Darrell Tan" <65300800>65300800>
o: keep-alive
l: 0
Note I have also gotten the WRP400 to trigger NOTIFICATION and the LYNC Server sees that SIP Message, moreover I had already turn off "REFER" from the Server based on some document highlighting the LYNC and CISCO UC conditions.
Do you have any ideas why the device does not response to the OPTIONS?
Thanks in advance.
Darrell Tan
05-23-2012 10:40 AM
HI Jet,
Please call the Small Business Support Center (SBSC)and speak with an agent and get a case started. Please refer to this thread when you are speaking with them. The phone numbers for SBSC are located here:
https://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
twitter: CiscoSBsupport
