WRP500 VOIP Issue
aferoz2000
Hi All,
I am using WRP500 device in our environment, we do not the use the external WAN capability of this router, nat or firewall instead we have this setup as layer 3 switch with 2 VLANS provide different wireless access.
we would like to use the fxs port to connect to a VoIP provider to one of the ports but for some reason the line just keep showing failed it’s not even trying to register with the voip server we have double check all credentials and everything but can’t seem to figure what is the issue the voice is enabled on the VLAN
Can someone guide me to the right path?
0 Replies 0
