AlternateExtension Advanced CUC 9.1.2ES59.12901-59
I need some help with configuring AlternateExtensionAdvanced via the Rest API.
I have configured an Alternate Extension via the rest api but I cannot see any AlternateExtensionAdvancedURI in teh returned XML as per the WIKI suggests.
(https://www.google.co.nz/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0CCgQFjACahUKEwjGy8Owup3HAhUkxqYKHZG6ANo&url=http%…)
I need to set 'Skip PIN When Calling From Known Extension'.
I get the following back even when the advanced options are manually configured.
($uri = 'https://'.$cuc_server . '/vmrest/alternateextensionadvanceds/' . $result->body->AlternateExtension[1]->ObjectId;)
  string(1316) "
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<AlternateExtensions total="2">
    <AlternateExtension>
        <URI>/vmrest/users/97cd276f-eca5-4c2d-a252-adc6003e7517/alternateextensions/b869a083-5101-42f4-a0ab-e96cd4c76c0f</URI>
        <IdIndex>0</IdIndex>
        <DtmfAccessId>47628</DtmfAccessId>
        <LocationObjectId>b75461fd-5c7f-4ca0-a6c8-605dc04d604a</LocationObjectId>
        <LocationURI>/vmrest/locations/connectionlocations/b75461fd-5c7f-4ca0-a6c8-605dc04d604a</LocationURI>
        <ObjectId>b869a083-5101-42f4-a0ab-e96cd4c76c0f</ObjectId>
        <PartitionObjectId>77f3b0e5-2058-488b-92b5-99e0aaac3e03</PartitionObjectId>
        <PartitionURI>/vmrest/partitions/77f3b0e5-2058-488b-92b5-99e0aaac3e03</PartitionURI>
    </AlternateExtension>
        <URI>/vmrest/users/97cd276f-eca5-4c2d-a252-adc6003e7517/alternateextensions/b10b5950-616a-4243-8f76-478222daca57</URI>
        <IdIndex>5</IdIndex>
        <DtmfAccessId>2947628</DtmfAccessId>
        <ObjectId>b10b5950-616a-4243-8f76-478222daca57</ObjectId>
</AlternateExtensions>"
Any help would be appreciated,
Bryan
Works in version 10.5.
Adam Pawlowski
E:
After working on this more and with the help of @avholloway , it seems that this advanced URI only appears if the Alternate Extension should have it.
Index 0 appears to represent the primary extension/partition for the subscriber, and it isn't subject to those properties.
Administrator defined alternates at least do have that property, and that key is returned for those entries.
