Please note that Remote Expert Mobile announced end-of-life and support will end on February 28, 2022.
815
Highlighted
Enthusiast
Can we Use Jabber SDK for IM on a web server
Trying to work out a program in which an email will trigger a jabber chat for that to happen , will need to run the Jabber IM chat 'jabberwerx.js'
on node.js
My question is node.js compatible with Jabber IM API ?
Is there any other way to run Jabber IM API   from a server instead of it requiring a user  input  from a webpage to send chat ?
Everyone's tags (3)
3 REPLIES 3
Re: Can we Use Jabber SDK for IM on a web server
The CAXL SDK (jabberwerx.js) relies heavily on jQuery and the browser DOM, so I don't think it will work via node.js (in any case it is not tested/supported with it.)
For server side IM&P, you will likely want to look at a 3rd party XMPP library appropriate to your platform and language of choice.  XMPP.org keeps a running list here (note, Cisco does not recommend or directly support any specific 3rd party XMPP library:) https://xmpp.org/software/libraries.html
Contributor
Any documentation on how to deal with SSO with these 3rd party libraries?   Being able to send IM (to individuals or persistent chat rooms) from a server event is huge.
Enthusiast
I have used node-xmpp  library and its working fine (although its without SSO)   , I think it can support  SSO also , by enabling modules like passport.
However I am not sure , if Cisco IMP server supports SSO yet
Content for Community-Ad
July's Community Spotlight Awards
