Cisco 99XX CiscoIPPhoneIconFileMenu
MichalWalczak
I have a problem with CiscoIPPhoneIconFileMenu. I'm using it to build my menu with png image in front of menu item. it all looks ok on 7962/7965 phones but on Cisco 99XX when there is more than 5 MenuItems on menu the first icon is shifted to the right and stretched. When I start to scroll icon is correct.
<?xml version="1.0" encoding="UTF-8"?>
<CiscoIPPhoneIconFileMenu>
<MenuItem><IconIndex>0</IconIndex><Name>0</Name><URL>http://10.122.128.5/directory</URL></MenuItem>
<IconItem><Index>0</Index><URL>http://10.122.128.5/directory/g.png</URL></IconItem>
</CiscoIPPhoneIconFileMenu>
Thanks for your help
Problem is still not resolved
Geevarghese Cheria
Hi Michal,
   CiscoIPPhoneIconFileMenu feature is supported on the 99xx series phones. Please refer this document  CiscoIPPhoneIconFileMenu  and make changes.
Thanks and Regards,
Geevarghese
Thanks for your help.
What exactly I have to change? Adding title and prompt doesn't change anything.
