Please note that Remote Expert Mobile announced end-of-life and support will end on February 28, 2022.
10287
Highlighted
Beginner
Crash issue using latest REM android SDK ES10(11.6.1)
I have integrated the latest REM android SDK ES10(Remote Expert Mobile Advanced and Expert Assist SDK for Android 11.6.1.10000-7-ES10.zip )(fusionclient-android-sdk3.2.2.2.1.jar) for our existing product which is working fine with older SDK(fusionclient-android-sdk3.2.2.jar).
However, while starting a REM call ,using this.callManager.createCall method it crashes whenever remote user joins the call. Below are the logs
08-09 11:43:47.030 14223-14710/com.stagrp.extcare.vcr E/art: No implementation found for void org.acbrtc.PeerConnectionFactory.initializeFieldTrials(java.lang.String) (tried Java_org_acbrtc_PeerConnectionFactory_initializeFieldTrials and Java_org_acbrtc_PeerConnectionFactory_initializeFieldTrials__Ljava_lang_String_2)
08-09 11:43:47.031 14223-14710/com.stagrp.extcare.vcr E/UncaughtException: java.lang.UnsatisfiedLinkError: No implementation found for void org.acbrtc.PeerConnectionFactory.initializeFieldTrials(java.lang.String) (tried Java_org_acbrtc_PeerConnectionFactory_initializeFieldTrials and Java_org_acbrtc_PeerConnectionFactory_initializeFieldTrials__Ljava_lang_String_2)
at org.acbrtc.PeerConnectionFactory.initializeFieldTrials(Native Method)
at com.alicecallsbob.fcsdk.android.phone.impl.PeerConnectionFactoryManager.getFactory(PeerConnectionFactoryManager.java:33)
at com.alicecallsbob.fcsdk.android.phone.impl.PeerConnectionClient.<init>(PeerConnectionClient.java:75)
at com.alicecallsbob.fcsdk.android.phone.impl.PhoneImpl.createNewCall(PhoneImpl.java:248)
at com.alicecallsbob.fcsdk.android.phone.impl.PhoneImpl.createNewCall(PhoneImpl.java:241)
at com.alicecallsbob.fcsdk.android.phone.impl.PhoneImpl.getOrCreateCall(PhoneImpl.java:904)
at com.alicecallsbob.fcsdk.android.phone.impl.PhoneImpl.access$400(PhoneImpl.java:61)
at com.alicecallsbob.fcsdk.android.phone.impl.PhoneImpl$6.run(PhoneImpl.java:650)
at java.lang.Thread.run(Thread.java:762)
08-09 11:43:47.195 14223-14584/com.stagrp.extcare.vcr I/System.out: (HTTPLog)-Static: isSBSettingEnabled false
08-09 11:43:47.196 14223-14584/com.stagrp.extcare.vcr I/System.out: (HTTPLog)-Static: isSBSettingEnabled false
08-09 11:43:47.268 14223-14626/com.stagrp.extcare.vcr D/MainActivity: Enpoint Status is ================Connected
08-09 11:43:47.306 14223-14710/com.stagrp.extcare.vcr E/AndroidRuntime: FATAL EXCEPTION: Thread-12
Process: com.stagrp.extcare.vcr, PID: 14223
2 REPLIES 2
Highlighted
Beginner
I can't find a reference anywhere on the web for:
You might have somehow renamed an import statement as the well known class is:
org.webrtc.PeerConnectionFactory
Otherwise it looks like a build problem. Similar to https://stackoverflow.com/questions/45015530/no-implementation-found-for-void-org-webrtc-peerconnectionfactory-initializeandr
Highlighted
Hi rdoyle
Thanks for your response.
I have not changed any import statement. Just replaced the jar and tried to run the app. It crashed once remote user joins the call or whenever call is established
Gautam
