Getting contact info
ivanapantelic
How can I get contact name and phone number if get-user-config returns only IMAddress, userName, listName and Calendar, and get-contact-info returns nothing? I use wsdl EPASSoap file from server.
npetrele
Get-contact-info returns vCard data if it is set.  It's not set by default.  You can set it with modify-contact-info to include things like phone number, etc.
Here's the page where you can find the documentation for your version of Cisco IM&Presence.
Cisco CUPAPI
You can find get-contact-info and samples in the documentation.
There is a setting in IM&P to build vCards from LDAP, but I have never gotten it to work.  It should work, so I'm obviously doing something wrong, but I haven't had time to explore what that is.  I suspect it's this caveat:  "A user’s vCard will become available only when it is published, typically on the client side."
Assuming there is a CUCM as part of the system, you may be able to retrieve that kind of info from CUCM (based on the user ID) via the AXL (server-to-server model) or UDS (user client model) APIs:
https://developer.cisco.com/site/axl/overview/
User Data Service - Cisco UDS
