How can an application find that a cisco phone has an active call?
Hello all,
We have an application that communicates with Cisco phones and pushes texts/images/.. to phones. Is it possible for the application to find out if there is an active call on the phone, before pushing a message?
Thanks for you inputs,
Parisa
Geevarghese Cheria
Hi Parisa,
  Hope you are using JTAPI\TAPI application  and i think if the call is active there is no chance to receive the events, Next time i would request you to post your query under IP Phone Services
Please refer this url - Waiting call  Which seems to be a similar issue that you are looking for.
Thanks and Regards,
Geevarghese
Hi Parisa,
I've moved the discussion to IP Phone Services forum. If using CiscoIPPhoneExecute, you can set the priority so that the message gets displayed on the phone after the call ends.
Adrienne
For the most reliable results, as mentioned the CTI APIs (TAPI/JTAPI) will allow applications to be notified via event in real-time of the call status of a phone.
Somewhat less reliable but potentially easier to implement: I've seen some applications query the /StreamingStatisticsX page (available from the phone's on-board web server) to identify whether it looks like the device has an active call stream.  See the IPPS apps dev notes doc for details on this URL.
