How to add more licenses to existing installation
william016
If for an initial order, there is 20 concurrent licenses installed for a production environment, and later add another 80 concurrent licenses, how do we merge the 80 licenses into the existing production environment, do we need to reinstall the REAS/REMB servers to have the total 100 concurrent licenses, or what steps needed technically to have the 80 concurrent licenses applied to the existing production environment?
William
dstaudt
Definitely recommend opening a case with Cisco TAC for REM product install/config assistance
