Jabber SDK CUCM configuration
Muaaz El Kamali
I am getting confused about is there is any configuration required on CUCM server for Jabber SDK for web?
I am using CUCM 91.2 and I have follow the steps to create a Client Services Framework with name ECPxxx. What else required on CUCM server.
gstancev
If you already created CSF device, you need to create Directory Number and End User(if it isn't created via LDAP) . You must associate CSF device and End User with Directory Number (in Directory Number configuration panel), and you must associate CSF device with End User(in End User configuration panel). After that you should login and use Jabber Web SDK.
Goran
Hi Goran,
I found in CUCM 10.5 one option is CORS ( Cross-Origin Resource Sharing) which is adding trusted domain to the CUCM. Is there is any similiar configuration required in CUCM 9.1.2?
Regards.
Muaaz
Hi Muaaz,
I think CORS is first time introduced with CUCM 10.5, so you won't find it in CUCM 9.1 configuration.
Goran
