Jabber SDK MR 11 web sample application for manual sign-in not working
Shruti Joshi
Jabber SDK Web MR 11, Sample Code was downloaded from: Cisco DevNet: SDK Web SDK - Voice and Video - Downloads and Docs
Run Sample.html,
The click on the link for manual Sign in fails to provide the required page for configuration of for Username, Password and CUCM.
Could you please provide the working Sample code for Manual Sign in.
Got the following steps through Support : We tried and its working.
Assuming everything is installed and working correctly (the plug in, the Chrome extension if you're using Chrome, etc.), then you may simply be running into a problem if you are trying to use sample.html directly as a local file.  It is written to be viewed and tested from a web server.
Something like this won't work:
file:///E:/Cisco/Jabber/VoiceVideo/samples/sample.html
But this should work fine (assuming you have a web server set up on your localhost, etc.):
http://localhost/VoiceVideo/samples/sample.html
