<CiscoIPPhoneExecute> Problem
dglanton1
Im wanting to send a <CiscoIPPhoneExecute> xml command to a 7921G phone. When i send the command, the phone shows "Host Not Found" and the response from my stream say "The remote server returned an error: (500) Internal Server Error." I want to write this in c# but could do it in Java also. This used to work for me a while back but it is not anymore. Any help would be appreciated!
My Code:
WebResponse resp = null;
string ErrorCode = "";
string ResponseXML = "";
string pushXML = "<CiscoIPPhoneExecute>";
pushXML += "<ExecuteItem Priority=\"0\" URL=\"Play:Vibe.raw\"/>";
pushXML += "</CiscoIPPhoneExecute>";
pushXML = "XML=" + HttpUtility.UrlEncode(pushXML);
string PhoneURL = string.Format("http://{0}/CGI/Execute", "MyIPAddress");
HttpWebRequest req = (HttpWebRequest)WebRequest.Create(PhoneURL);
req.Method = "POST";
req.AllowAutoRedirect = false;
req.ContentType = "application/x-www-form-urlencoded";
req.Credentials = GetCredentials("MyUsername", "MyPassword");
byte[] bytes = null;
bytes = System.Text.Encoding.UTF8.GetBytes(pushXML);
Stream outputStream = req.GetRequestStream();
outputStream.Write(bytes, 0, bytes.Length);
outputStream.Close();
resp = req.GetResponse();
Stream s = resp.GetResponseStream();
StreamReader stm = new StreamReader(s);
if (stm == null)
     "Timed out or no response!";
else
          ResponseXML = stm.ReadToEnd();
          stm.Close();
s.Close();
resp.Close();
amoherek
Hi Dexter,
Did you add Vibe.raw to the TFTP server? If so, you may have to restart the TFTP service via UCM Serviceability.
Adrienne
