MUC Jabber Sample Code Available?
jmennear
Would it be possible to get some sample code on doing a multi-user chat?
5 Replies 5
tinghche
Level 5
Level 5
Hi John,
Have you checked out the sample code "mucexample.html"?
Howard
npetreley007
mucexample.html is in the CAXL SDK under doc/examples
You can also find the mucexample.html online here:
https://developer.cisco.com/media/AJAX-XMPP-Library-Index/examples/mucexample.html
Here's the link from the library index:
https://developer.cisco.com/site/collaboration/jabber/websdk/develop-and-test/im-and-presence/xmpp-library-reference/ind…
npetrele
Here are two samples (attached) updated to include jQueryUI.  npMucDemo works with the sandbox.  npjQueryUiDemoWebex works with webex.
Nicholas,
This is great.  Anyone have an example an XMPP Client on 5222?
Mike
Hi Mike,
Cisco doesn't have an API for that, only CAXL, which is web-based and uses BOSH (7335), not 5222.
You can use a variety of open source APIs that should work.  I've played with Smack (Java), and I found it very simple to use.
If you want to see how others do it, there are at least two open source Jabber clients that use XMPP and 5222.  Pidgin is one, Jitsi is another.  You can download the source for each and have a look.
Nicholas
