Node CSF express 4.x
adrianchia
Beginner
Beginner
When I run the node component via
npm installcsf-3.0.6-168364.tar.gz
and
node node_modules/csf/csf.js
it shows
node_modules/csf/csf.js:105
app.configure(function() {
TypeError: Object function (req, res, next) {
    app.handle(req, res, next);
  } has no method 'configure'
    at Object.<anonymous> (/home/vagrant/jabber/node_modules/csf/csf.js:105:5)
    at Module._compile (module.js:456:26)
    at Object.Module._extensions..js (module.js:474:10)
    at Module.load (module.js:356:32)
    at Function.Module._load (module.js:312:12)
    at Function.Module.runMain (module.js:497:10)
    at startup (node.js:119:16)
    at node.js:902:3
after digging around I found out that in express 4.x has removed app.configure(...) function. Is there any update on this?
https://github.com/visionmedia/express/blob/master/History.md
Geevarghese Cheria
Hi Adrain,
Express 4.x does not have configure method.
https://github.com/visionmedia/express/wiki/Migrating-from-3.x-to-4.x
Also, it doesn't have express.logger and express.bodyParser had been deprecated ages ago.
Reference - javascript - TypeError: Object function (req, res, next) { app.handle(req, res, next); } has no method 'configure' - Sta…
Thanks and Regards,
Geevarghese
Recognize Your Peers
