I need help with creating a macro on a CE 9.12+ codec (Room Kit Plus), please.
What I want is a macro that will disable Multistream mode ("xConfiguration Conference MultiStream Mode: Off") when the codec dials a call to Webex (*.webex.com), and re-enable it when it is no longer connected to Webex. These are on-prem registered codecs.
The reason for it is that the customer needs to be able to use local multisite even in a Webex call, and this setting, when On, appears to prevent local multisite calls from working in a Webex call.
Due to the multisite usage, the codec could be in multiple calls, 1 or more local and 1 Webex at the same time, so the programming logic around determining if the codec is/is not in a Webex call, and when to turn off MultiStream mode is a bit complicated.
Although maybe a better way to make it would be to Disable MultiStream mode only when the codec dials out to something else while already in a call with Webex? Not sure on that.
Thanks!
