09-14-2014 08:16 PM
Dear team,
we met a problem that when we using the web jabber on the macbook with the explore of safari. the error shows as the following "Login error eCouldNotConnect".
The Cisco Call Manager version is 8.0.3-2000
many Thanks
09-15-2014 12:49 PM
The first thing I would do is check to see if what you're entering here is correct for your server, see example below. (I blurred out our IP address - put the IP address of your CUCM in that spot.) Click Login first, and then Connect. If you still have problems, let me know.
09-16-2014 12:08 AM
Yes,I do the steps what you say,I also have this problem on the mac book air.
10-20-2014 09:46 AM
Make sure your user on CUCM is configured correctly, has the appropriate privileges (access control groups), and that one of the controlled devices for that user is a CSF soft phone.
09-16-2014 01:50 AM
Hi Chao, can you send log file after Login error? That may help us to find problem.
10-17-2014 09:28 PM
I do have same error message encounter.
Unable to login: Login Error eCouldNotConnect
The setup is:
CUCM install on 192.168.1.7 and my sample.html install on 192.168.1.11.
I already create new user one cucm which I use to login. Also tyry the admin login but the error still persists.
Question:
1. Any idea on how to verify that the request recieve on the cucm(Maybe logs on CUCM)
2. 192.168.1.11 is just server where only installed is the webser who server the content(sample.html).
10-24-2014 04:03 AM
Just to close my follow-up question since I already fixed it.
10-20-2014 08:32 PM
Hi Chao,
We met this before.
Make sure your network clear, check your CUCM server stress and restart the CUCM would be helped.
If not, debug the 'cwic.js' to see where makes this error.
Thanks Jeff.
10-20-2014 11:23 PM
Hi Jeff,
OK,I will try it.
