REM Advanced SDK objC
Problem delegate is not called. Connection is established. Input/output streams to host works. But delegates is not called. I have no idea why. I linked all frameworks just like in example app iOSFusionSDKSample and set "enable bitcode" to NO and other linker flags to "-ObjC -lstdc++" and I did try "AssistSDK" it works but i cant control style and size and other options in it.
Code "ViewController.m"
#import "ViewController.h"
@interface ViewController () {
    NSURLSession *session;
@end
@implementation ViewController
- (void)viewDidLoad {
    [super viewDidLoad];
    // Do any additional setup after loading the view, typically from a nib.
- (void)viewDidAppear:(BOOL)animated {
    [super viewDidAppear:animated];
    NSURLSessionConfiguration *config = [NSURLSessionConfiguration defaultSessionConfiguration];
    session = [NSURLSession sessionWithConfiguration:config delegate:self delegateQueue:[NSOperationQueue mainQueue]];
    NSURL *url = [NSURL URLWithString:@"#####"];
    NSURLSessionDataTask *task = [session dataTaskWithURL:url completionHandler:^(NSData * _Nullable data, NSURLResponse * _Nullable response, NSError * _Nullable error) {
        NSLog(@"%@", data);
        NSLog(@"%@", response);
        NSString *responseString = [[NSString alloc] initWithData:data encoding:NSUTF8StringEncoding];
        NSDictionary *json = [NSJSONSerialization JSONObjectWithData:data options:NSJSONReadingMutableLeaves error:&error];
        NSString *sessionId =  [json valueForKey:@"sessionid"];
        ACBUC *uc = [ACBUC ucWithConfiguration:sessionId delegate:self];
        [uc setNetworkReachable:NO];
        [uc acceptAnyCertificate:YES];
        [uc startSession];
        [uc setNetworkReachable:YES];
    [task resume];
- (void)didReceiveMemoryWarning {
    [super didReceiveMemoryWarning];
    // Dispose of any resources that can be recreated.
- (void)URLSession:(NSURLSession *)session didReceiveChallenge:(NSURLAuthenticationChallenge *)challenge completionHandler:(void (^)(NSURLSessionAuthChallengeDisposition, NSURLCredential * _Nullable))completionHandler
    if ([challenge.protectionSpace.authenticationMethod isEqualToString:NSURLAuthenticationMethodServerTrust] &&[challenge.protectionSpace.host isEqualToString:@"####"])
        NSURLCredential *credential = [NSURLCredential credentialForTrust:challenge.protectionSpace.serverTrust];
        completionHandler(NSURLSessionAuthChallengeUseCredential, credential);
    else
        completionHandler(NSURLSessionAuthChallengeCancelAuthenticationChallenge, nil);
- (void)ucDidFailToStartSession:(ACBUC *)uc {
    NSString *string = @"SDFSDF"; // Breakpoint
- (void)ucDidLoseConnection:(ACBUC *)uc {
- (void)ucDidReceiveSystemFailure:(ACBUC *)uc {
- (void)ucDidStartSession:(ACBUC *)uc {
@end
Code "ViewController.h"
#import <UIKit/UIKit.h>
#import <ACBClientSDK/ACBUC.h>
#import <ACBClientSDK/ACBClientPhone.h>
#import <ACBClientSDK/ACBClientCall.h>
@interface ViewController : UIViewController <NSURLSessionDelegate, ACBUCDelegate>
@end
Debug LOG output:
ACB client SDK version: 3.2.2.1.1
Scrambled Session ID:#####
Session ID:wss://#####
***WEBSOCKET*** setNetworkReachable: 0
***WEBSOCKET*** NTWK acceptAnyCertificate: 1
Created NSURLRequest: wss://### with timeout of: 7.000000
Waiting for network reachability before websocket is created.
***WEBSOCKET*** setNetworkReachable: 1
Creating websocket to <NSMutableURLRequest: 0x1c001c960> { URL: wss://#### }
SocketRocket: Allowing connection to any root certificate
[SR] Don't Use Cookies
Problem solved,
var ACBUC needs to be in class scope not in function scope.
After this little modification it seams to work.
Matous
