Please note that Remote Expert Mobile announced end-of-life and support will end on February 28, 2022.
1129
Highlighted
REM Web SDK Expert Assist popup
Hi is it possible to disable expert assist popup or hide him ? I want connect to agent witth simple page without popup.
1 ACCEPTED SOLUTION
Highlighted
Not applicable
Hi Lukasz,
If you are using co-browse only then this will automatically not have the popup with the agent's video image from REM 11.5.
For V&V calls in REM 11.5 the pop up will remain the same as in REM 10.6
Rob
10 REPLIES 10
Highlighted
Not applicable
Hi Lukasz,
Rob
Highlighted
No I am not using Co-browse. I use only Video and Audio connection.
Highlighted
Hi Lukasz,
Can you share a screen shot of what you want removed.
If you are only using Video and Audio connection  (and no co-browse) then in REM 11.5 you will be able to use the advanced SDK and will have complete control over your local and remote video windows.
Rob
Highlighted
I want remove/hide this popup
Highlighted
Hi Lukasz,
This popup window in the browser is used to maintain the call during traversal of pages so it can't be removed but it can be customized with regard to colors, fonts, and images. To customize it, create a CSS file defining styles for the body tag and for the #title, #logo, and #status elements. When invoking, you must pass the CSS file URL as the popupCssUrl configuration parameter
See the "Customizing the JavaScript CSDK popup window" section of the developer guide for more details.
Rob
Highlighted
Hi Robert
I was able to do for Chrome and Opera Browsers but for Firefox and IE it doesn't work. I replaced "parent window" on "expert assist window" by simple change in code. For Chrome it looks before:
After:
Highlighted
Hi Likasz,
Thanks for sharing. Is this issue resolved for you now?
Cheers,
Rich
Highlighted
Hi Richard.
I can't fix this issue for Firefox and IE. I need resolve issue for all browsers IE > 9, Firefox, Opera, Chrome, Safari. I changed one line of code in assist.js
function loadPopup(callback) {
            controllerWindow = window.open("about:blank", '_self', "width=" + CONTROLLER_WIDTH + ",height=" + CONTROLLER_HEIGHT + ",resizable=yes,scrollbars=yes");
And it's work fine for Chrome and Opera browsers.
Highlighted
Hi Lukasz,
I don't think this feature, hiding the assist popup is supported in REM. Can you attach your full assist.js file?
Cheers,
Rich
Highlighted
