Hi all,
I'm working on Jabber Guest IOS SDK.
When I run the sample, I got some error.
It confused me for hours.
I'm a beginner on this.
Just one question.
Jabber Guest SDK for IOS can only be run on IOS device? Is the simulator be supported?
Jeff
Solved! Go to Solution.
The error indicates that the Jabber Guest framework component, which includes arm7 architecture compiled/optimized code, is unable to link for the simulator, which runs as an i386 architecture process on the Mac OS.
I believe this is a common limitation when working with media/graphics related app development for iOS, in general.
As I understand it, the Jabber Guest for iOS framework uses OS audio and video capabilities that are not possible to simulate. Development should be conducted on a physical device.
What is the specific error you are seeing?
Hi, team,
If so, I had to pay $99.
Is it possible to make 'JabberGuest.Framework' fit for the simulate?
The Error:
Undefined symbols for architecture i386:
"_OBJC_CLASS_$_CJGuestCallViewController", referenced from:
objc-class-ref in CJSAppDelegate.o
ld: symbol(s) not found for architecture i386
clang: error: linker command failed with exit code 1 (use -v to see invocation)
Jeff
