SASL Error even with correct credentials
ciscojavauser
HI ,  I am  trying to connect with finesse notification service with cisco jabber api.
some times I am getting  {urn:ietf:params:xml:ns:xmpp-sasl}not-authorized . even with correct credentials.
trying login few times it works .
this problem becomes worst when application try to recover a failover.
Please suggest .
Geevarghese Cheria
Hi Javadev,
If you are using  "IP address" for the "domain" config in your CAXL setting Please try using the "domain name" .
The domain name is the domain name that your CUPS server belongs to.
CUPS->System->Cluster Topology->Settings->Domain Name
Reference -Jabber UI Demo - Bind Error
Thanks and Regards,
Geevarghese
