TC Console 7.1 - Failure to Communicate
JOEL FREDERICK
Beginner
Beginner
When attempting to connect to a C60 running TC7.1.0 or TC7.1.1 I get the following message:
"Failed to communicate properly to the codec.  Some components failed to initialize."
Please let me know what is needed to resolve this communication issue.  Thanks!
6 Replies 6
Geevarghese Cheria
Hi Joel,
   I would request you to refer  the following link TC Console issues for related information.
Thanks and Regards,
Geevarghese
David_Bruun-Lie
Joel,
we're putting up a new version that fixes a regression when attempting to log in on certain codecs. Sorry about this.
See you at infocomm?
David
David, I appreciate the update here.   I will not be attending InfoComm this year however one of my co-workers will be there to represent.   Thanks
Joel, a new TC console version has been published now, please try it out. Sorry for the inconvenience and thanks for the feedback! :-)
David
OK, it appears that all of the TC Console download links (including previous versions) are not working at the moment.  I will check back later.   thanks.
Downloaded 7.1.1 and connected to the C60 now.  I'll let you know if I run into any issues.  Thanks again!
Recognize Your Peers
