Beginner
ACI Learning Labs problem
Hi all,
I'm stuck with a problem on ACI Programmability Options lab, section APIC Sandbox Environment Setup, it says:
# From within the correct virtual environment (venv) apic_fabric_setup\ $ python baseline.py
# Expected Output
Baselining APIC Simulator for Learning Labs
Setting up Fabric Nodes
Configuring Fabric Policies
Setting up Common Tenant
Setting up Heroes Tenant
Setting up SnV Tenant
But my output is:
(venv) C:\Python27\aci-learning-labs-code-samples\apic_fabric_setup>baseline.py
Traceback (most recent call last):
  File "C:\Python27\aci-learning-labs-code-samples\apic_fabric_setup\baseline.py", line 11, in <module>
    import startup_script
  File "C:\Python27\aci-learning-labs-code-samples\apic_fabric_setup\startup_script.py", line 225, in <module>
    md.commit(c)
  File "c:\python27\lib\site-packages\acicobra-3.0_1k-py2.7.egg\cobra\mit\access.py", line 63, in commit
    return self._accessImpl.post(configObject)
  File "c:\python27\lib\site-packages\acicobra-3.0_1k-py2.7.egg\cobra\internal\rest\accessimpl.py", line 176, in post
    return self.__parseError(rsp, CommitError, rsp.status_code)
  File "c:\python27\lib\site-packages\acicobra-3.0_1k-py2.7.egg\cobra\internal\rest\accessimpl.py", line 234, in __parseError
    parseXMLError(rsp.text, errorClass, httpCode)
  File "c:\python27\lib\site-packages\acicobra-3.0_1k-py2.7.egg\cobra\mit\xmlcodec.py", line 15, in parseXMLError
    raise errorClass(int(errorCode), errorStr, httpCode)
cobra.mit.request.CommitError: Validation failed: Validation failed for node: 102Overlapping interfaces. Last examined: uni/infra/accportprof-dci-l3out-104
Any ideas what I may have done wrong?
4 REPLIES 4
Re: ACI Learning Labs problem
You are NOT doing anything wrong.
Overlapping interfaces - server has something already configured
Beginner
Hello all, so what is the fix here?  I am running into a similar issue within the 1st page of the
Intermediate ACI Programmability module
I run the baseline.py script and I get the following , looks like it is not able to import anything in the cobra library:
(venv) C:\Python27\CISCO_DEVNET\aci-learning-labs-code-samples\apic_fabric_setup>python baseline.py
File "baseline.py", line 11, in <module>
File "C:\Python27\CISCO_DEVNET\aci-learning-labs-code-samples\apic_fabric_setup\startup_script.py", line 3, in <module>
import cobra.mit.access
File "C:\Python27\CISCO_DEVNET\aci-learning-labs-code-samples\venv\lib\site-packages\acicobra-3.2_1m-py2.7.egg\cobra\mit\__init__.py", line 2, in <module>
from ._mit import Mit
File "C:\Python27\CISCO_DEVNET\aci-learning-labs-code-samples\venv\lib\site-packages\acicobra-3.2_1m-py2.7.egg\cobra\mit\_mit.py", line 8, in <module>
topRoot = importlib.import_module('cobra.model.top')
File "C:\Python27\Lib\importlib\__init__.py", line 37, in import_module
__import__(name)
ImportError: No module named model.top
Everyone's tags (4)
Beginner
I had same issue with interface profiles- validation failed overlapping interfaces error
the solution was that I was missing the to and from port in the range.
"children": [{
"infraPortBlk": {
"attributes": {
"dn": "uni/infra/accportprof-LEAF{{node}}/hports-E{{port}}-typ-range/portblk-block2",
"fromPort": "{{port}}",
"toPort": "{{port}}",
I added those two values and it now works.
Highlighted
Beginner
the APIC API blows.  I'm running 4 code and i'm getting the same error from my APIC.  I go and delete the interface from the access port selector list and then try to readd it thru API and can't.
Their validation is not in sync with is showing up in the APIC GUI.  It seems like once you create a policy in the GUI, you can't recreate it in the API if it's ever been created.  There must be something somewhere else holding onto the values in the port profile/interface selecctors.
Did you ever get a solution to this issue?
Content for Community-Ad
August's Community Spotlight Awards
