1123
ACI Simulator 4.4.2e failed instalation
I´m trying to install the simulator using the OVA file. When I deploy it everything goes fine until almost reaching the 100% I get the next error:
"Failed - Upload disk cancelled"
"Failed - The task was canceled by user"
Do I need to have a special vmware version? Or is it something else I´m missing?
3 REPLIES 3
Hi Fernando,
 I have deployed ACI Simulator 4.2(6d) in VMWare Workstation 15 for Windows 10 Successfully. I'll share a video tutorial as soon i upload it to YouTube. But in the meantime i have a few questions to know your scenario.
  1. Did you download and concatenate all the 5 parts? Which tool or command did you use?
  2. Did check if all 5 parts are around 8 GB size?
  3. Which VMWare are you using?
  4. Can you share a screenshot of the error?
  5. Do you have at least 32 GB of RAM?
Hey Hi. Thanks for your reply.
Well, the installation steps are quite simple. I think it was a vmware problem.
I solved it using a different datastore. No idea why it didnt want to be installed correctly on the first I used.
By now is fine and working with this version.
I appreciate your help. Hope we can soon watch that video of yours.
Regards!
Nice. I'm glad you solved it.
Here i'm sharing the links of the video tutorial, hope it's useful. i created a english version and a spanish version:
English Version: How to Download and Install Cisco ACI Simulator on VMWare Workstation 15 for Windows 10?
https://youtu.be/_tmxdSkgZ3U
Spanish Version: ¿Cómo descargar e instalar el Cisco ACI Simulator en VMWare Workstation 15 para Windows 10?
https://youtu.be/EMuMldkOC-Q
In this video we are going to learn step by step how to Download and Install Cisco ACI Simulator on VMWare Workstation 15 for Windows 10.The Cisco ACI Simula...
En este video, aprenderemos paso a paso cómo descargar e instalar el Cisco ACI Simulator en VMWare Workstation 15 para Windows 10.El enlace de descarga del s...
Create
Recognize Your Peers
Content for Community-Ad
