05-11-2017 02:34 AM
I am preparing some ACI API testing scenario's and would like to make use of acitoolkit.
Now I would like to know;
- Does acitoolkit run with Python 3 or not?
- Which Linux platform and version is best to use for acitoolkit to run on.
Many thanks for the reply!
11-23-2017 09:59 AM
Hello, you need whatever linux distro, you can use ubuntu or centos
i thinks it use 2.7, but it doesn't care about the version, because you can use what's come in the machine
and start to build a scripts
07-24-2020 04:56 AM
I found this runs very well with centos 8 and python3.7
one problem was the diagram app section
one dependency is not available in the standard centos repos anymore so YUM fails for:
graphviz-devel.x86_64
to get this to work enable Centos PowerTools repo (via GUI software tools or CLI - disabled by default)
you can then install from this repository and the lab works nicely
sudo yum repo-pkgs PowerTools list | grep graphviz
sudo yum repo-pkgs PowerTools install graphviz-devel.x86_64
