I am trying to configure the ospf on the router in CML lab through ansible. Snippet of my playbook and host_var is attached:
this is the result that i am getting
TASK [Configuring OSPF on Routers] *******************************************************************************************************************
changed: [10.10.20.200] => (item={'address': '192.168.0.0', 'mask': '0.0.0.255', 'area': 0})
changed: [10.10.20.201] => (item={'address': '192.168.0.0', 'mask': '0.0.0.255', 'area': 0})
changed: [10.10.20.200] => (item={'address': '192.168.1.0', 'mask': '0.0.0.255', 'area': 0})
PLAY RECAP *******************************************************************************************************************************************
10.10.20.200 : ok=5 changed=2 unreachable=0 failed=0 skipped=0 rescued=0 ignored=0
10.10.20.201 : ok=4 changed=2 unreachable=0 failed=0 skipped=0 rescued=0 ignored=0
But when i am running the sh run command on the router , i can see that the network is not advertised
router ospf 1
area 0 capability default-exclusion
area 0 authentication
What is the error here? I am not able to figure out.
