08-16-2016 03:31 AM - edited 03-01-2019 04:30 AM
I'm currently trying to use the APIC-EM PNP feature to configure Access-points running 8.3 with the WLC-IP, Ap-MODE, AP-Group and FlexConnect-Group.
I can't find the JSON syntax for WLC 8.3 software (AP image 15.3(3)JD).
The 8.2 syntax shows as follows:
{"apGroup":"BldgA-local","primaryWlcIP":"10.10.80.5","primaryWlcName":"5508-1","secondaryWlcIP":"10.10.80.6","secondaryWlcName":"5508-2","tertiaryWlcIP":"10.10.10.7","tertiaryWlcName":"8500-1","apMode":" flexconnect"}
But I'm missing the FlexConnect Group setting added in 8.3.
Ralph
Solved! Go to Solution.
08-16-2016 04:26 AM
"apFlexGroupName" : "flexgroup" for example.. It is just another attribute.
That should be all you need.
And you need to remove the "apGroup" attribute.
08-16-2016 04:14 AM
That would be apFlexGroupName
Note: You also need to set the apMode as well.
08-16-2016 04:21 AM
Yeah, I'm already setting the apMode, but I'm missing the syntax for the flexConnectGroup.
08-16-2016 04:26 AM
08-16-2016 04:37 AM
Ohh. missed the "apFlexGroupName the first time.
(Will test right away)
So you can't set both apGroup and apFlexGroupName?
Do you know if any documentation exists for this? I can't seem to find it.
08-16-2016 04:51 AM
Both apGroup and apFlexGroupName works fine together.
Thank you.
"primaryWlcName":"BranchWLC-A",
"secondaryWlcName":"BranchWLC-B",
"tertiaryWlcName":"BranchWLC-HA",
"apMode":" flexconnect",
"apGroup":"APGrp-BranchA",
"apFlexGroupName":"FlexGrp-BranchA"
08-17-2016 07:14 PM
Yes you are correct. You can have both.
10-25-2016 07:58 AM
Is there a document that lists all of the configurable attributes?
For example how did you aradford know that flexGroup was an attribute that could be set?
10-26-2016 01:51 AM
Hi Justin,
I'm also missing documentation.
Adam has inside information And he was sure fast to answer the request when I posted it originally.
Ralph
10-26-2016 10:57 AM
Yes, I do have some inside information, I am an SE @ Cisco, so spoke to engineering team.
I am trying to get a definitive list for you all.
I have some that I know about, I just want to make sure I have them all.
Will update soon.
Adam
12-09-2016 08:59 AM
Do you have any updates to this?
12-11-2016 01:40 AM
Are the ones that are documented. There are 9 options in total. You only need to specify a primate wlcIP and wlcName, no need to provide secondary and tertiary.
Adam
11-13-2017 03:32 PM
Hi Adam,
Has this list been extended to allow for more options in the JSON file?
Brad
12-09-2016 09:03 AM
Can you confirm that apFlexGroupName is accurate? It does not appear to be taking that setting, but the other documented ones work. Here is my sanitized config
"primaryWlcIP": "1.1.1.1",
"primaryWlcName": "primary",
"secondaryWlcIP": "2.2.2.2",
"secondaryWlcName": "secondary",
"apMode": "flexconnect",
"apGroup": "APGroup",
"apFlexGroupName": "Flex-100"
12-11-2016 01:38 AM
Hi Justin,
sorry for the dumb Q, but are you sure it is 8.3 image on the AP?
That is the only version that supports apFlexGroupName
This community is intended for developer topics around Data Center technology and products. If you are looking for a non-developer topic about Data Center, you might find additional information in the Data Center and Cloud community
