Community Helping Community
1902
Beginner
APIC-EM controller failing to start services
I had to power down the controller for some hardware maintenance. I did this according to the official guide Cisco Application Policy Infrastructure Controller Enterprise Module Installation Guide, Release 1.4.x - Configuring Ci…
But now I cannot login to the controller.However I can ssh to grapevine. Below is some queries I did to check system status:
Any help is really appreciated.
Everyone's tags (1)
1 ACCEPTED SOLUTION
Highlighted
Re: APIC-EM controller failing to start services
looks like the services (apart from grapevine) have not restarted.
Can you do a "./bin/reset_grapevine" and say "N" to the prompts.
It should show the services restarting.   when you do a "grape service display  | grep service_type" there should be  about 38 services.
ipgeo-service             service_type              ipgeo-service
apic-em-inventory-manager-service service_type              apic-em-inventory-manager-service
file-service              service_type              file-service
pnp-service               service_type              pnp-service
ip-pool-manager-service   service_type              ip-pool-manager-service
access-policy-programmer-service service_type              access-policy-programmer-service
election-service          service_type              election-service
scheduler-service         service_type              scheduler-service
app-vis-policy-programmer-service service_type              app-vis-policy-programmer-service
network-poller-service    service_type              network-poller-service
postgres                  service_type              postgres
qos-lan-policy-programmer-service service_type              qos-lan-policy-programmer-service
qos-policy-programmer-service service_type              qos-policy-programmer-service
task-service              service_type              task-service
router                    service_type              router
iwan-analytics-service    service_type              iwan-analytics-service
nbar-policy-programmer-service service_type              nbar-policy-programmer-service
rabbitmq                  service_type              rabbitmq
grapevine-coordinator-service service_type              grapevine-coordinator-service
apic-em-jboss-ejbca       service_type              apic-em-jboss-ejbca
grapevine-log-collector   service_type              grapevine-log-collector
policy-manager-service    service_type              policy-manager-service
rbac-service              service_type              rbac-service
topology-service          service_type              topology-service
grouping-service          service_type              grouping-service
telemetry-service         service_type              telemetry-service
identity-manager-pxgrid-service service_type              identity-manager-pxgrid-service
reverse-proxy             service_type              reverse-proxy
cas-service               service_type              cas-service
policy-analysis-service   service_type              policy-analysis-service
pfr-policy-programmer-service service_type              pfr-policy-programmer-service
grapevine                 service_type              grapevine
apic-em-event-service     service_type              apic-em-event-service
cassandra                 service_type              cassandra
apic-em-network-programmer-service service_type              apic-em-network-programmer-service
apic-em-pki-broker-service service_type              apic-em-pki-broker-service
node-ui                   service_type              node-ui
visibility-service        service_type              visibility-service
4 REPLIES 4
Highlighted
Beginner
Thank you. It's working now
Beginner
Thank you very much.
This helped me A LOT.
Thanks from me too! Also helped!
Content for Community-Ad
FusionCharts will render here
