06-17-2016 09:53 AM - edited 03-01-2019 04:28 AM
I've been trying to install APIC-EM v1.2 with 16 GBs of RAM for demo purposes. However, it fails trying to initialize the Grapevine services.
Anybody else with that problem?
Solved! Go to Solution.
06-17-2016 10:02 AM
Actually Joe the LAB version is shipping 1.2. It only requires 16G.. however:
we are about to change the release notes slightly.
a lab version requires anything from 16-24G.
If your disk performance is not good, you should opt for more RAM.
Ideally you should use 24G, but there is a slight bug at present (1000^3 < 1024^3) so max you can use is 22G
See how you go with 22G.
Just to be clear, this is not a different image, it is the same code, it just detects the limited RAM and boots in lab mode. all services work, but only 20 devices are supported.
06-17-2016 09:55 AM
Anyone trying that should, Jose :-). You need a minimum of 40 GB. I have this working at home, and I am able to use all of the features with my small four-node network.
06-17-2016 10:02 AM
06-17-2016 11:58 AM
Cool! Last time I tried with 16 GB, it did what Jose describes (Grapevine services didn't fully start). I've always had luck with 40 GB, but maybe I'll try out a 22 GB build.
06-29-2016 06:20 PM
The 22 GBs installation didn't work but the disks in that server are really slow. For the moment, we went with the 64 GBs installation. As soon as we can, we'll try to do installations with lower memory settings and share our results.
06-30-2016 07:55 AM
You may not want to waste your time, but I'd be curious to know if you can make it work with 40 GB (instead of the full 64). I have "meh" disks, and 40 is working fine for me in my lab.
07-03-2016 09:41 AM
you might find that does not work with 1.2.
There is a check with three thresholds:
Cisco APIC-EM will discover your host's available memory during the deployment process and will provide the following responses and options:
07-11-2016 05:48 AM
@aradford Hi, when you say only 20 devices are supported, does this include the PnP cababilities? Will it stop pushing configurations out after it's provisioned 20 devices?
07-11-2016 05:56 AM
Hi Rob,
technically no. The only complication is that part of the PnP process is to add the device to the inventory.
That is when you might have issues.
The best option would be to delete the device from inventory once it has been provisioned by PnP.
there is no "hard limit" on the number of PnP configurations you can make.
07-11-2016 06:01 AM
ok, thanks.
Do you know if the PnP capabilities might ever be siphoned off APIC-EM as a standalone product/service, as this is the only capability of the APIC that we need and it would be good to be able to run PnP separately on lower end hardware?
07-20-2016 01:23 PM
Rob,
If you use Prime, you can also do PnP there. http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-0/user/guide/pi_ug/plugandplay.html
07-20-2016 01:28 PM
PI is moving towards using APIC-EM as the PnP engine. Today you can use PI standalone, but long term direction will be to have APIC-EM as the "universal PnP engine". It will be optimised...
07-20-2016 01:27 PM
stay tuned on that request... sounds like a good idea :-)
06-17-2016 10:11 AM
Thank you.
I'll try to do the installation today with 22 GBs. If I manage to do it, I'll let you know.
06-17-2016 10:17 AM
let us know. probably easier than getting faster disk :-)
200M is the disk IO that APIC-EM specs, if you have significantly less than that, you will need more RAM.
This community is intended for developer topics around Data Center technology and products. If you are looking for a non-developer topic about Data Center, you might find additional information in the Data Center and Cloud community
