02-28-2017 12:31 AM - edited 03-01-2019 04:36 AM
Why do you need to deploy 3 VM for APIC-EM redundancy?
If I have 2 ESX Servers, 2 VM are enough ?
Solved! Go to Solution.
02-28-2017 12:48 AM
Hi Sebastien,
This is based on a fundamental concept in distributed computing called "split brain".
If one VM is not able to see the other, it could be due to the other node failing or the link to the other node failing.
In the scenario of the link failing, both sides could potentially continue to process requests (split brain) which would cause issues when they were reconnected. Which version of the "truth" would you trust?
To address this, if a cluster is partitioned, it needs to have >50% of the members active.
The minimum cluster size you need to do this is 3.
Which is why 3 is usually the minimum number of members for any HA cluster.
It is also why clusters often have odd numbers of members.
With APIC-EM, if you only have 2 VM in a cluster, and one VM goes down, the cluster goes down.
Adam
02-28-2017 12:48 AM
Hi Sebastien,
Adam
02-28-2017 05:03 AM
Hi Adam,
Thank you for the explanation !
03-08-2017 01:21 PM
Hi Adam,
For Multi hosts deployment, in Release notes 1.4, it is necessary to have 8x 900 GB HDD = 7,2 TB for each host in the APIC-EM cluster. It is outsize ...!
Is it a mistake or is it correct ?
03-09-2017 12:50 AM
let me check. I do not think that is the intention.
03-14-2017 08:04 AM
Hi Adam,
Do you have any news about HDD size on APIC-EM cluster ?
/Seb
03-15-2017 01:11 AM
no, but chasing it... thanks for reminder.
09-04-2017 12:58 PM
Hi Adam,
We have a multihost cluster with 3 nodes running release 1.4.3.1009.
This infrastructure worked for several months (we use Plug and Play application).
Our APIC-EM is not reachable trough HTTPS, we have a “502 Bad Gateway” error message (we tried with Internet Explorer, Chrome and Firefox but we have the same issue). SSH still working without any problems.
Did you already have this problem ?
This community is intended for developer topics around Data Center technology and products. If you are looking for a non-developer topic about Data Center, you might find additional information in the Data Center and Cloud community
