APIC-EM with ISR C1117-4PM
JPvisltgb
Level 4
Level 4
We got new devices for testing and now I'm trying to test provisioning. Officially this model is not supported, at least when you are adding new device you can't choose  product id (C1117-4PM) from the list in APIC-EM.
The problem is :
Due to advanced configuration of routers (distinct VRF for management) there is  configuration:
pnp profile pnp-zero-touch
backup transport https host 10.10.10.10 port 443 vrf for_management
So after device got all configuration it looses it connection with main transport but after sometime it should be able to connect to backup with source vrf. I have tested this config with ISR4321 and it works.
But with C1117-4PM seems that it doesn't try to connect to backup transport.
Here is output of  show pnp profile:
PnP Profiles: Active:1, Created:1, Deleted:0, Hidden:0
Name            CBType Node     Primary-Path           Primary-Trans  Backup-Trans
pnp-zero-touch  DNS    visible  pnp/WORK-REQUEST       HTTPS          HTTPS
Initiator Profile pnp-zero-touch: 1 open connections: 0 closing connections
        Encap: pnp
        WSSE header is not required. Configured authorization level is 1
        SID:[-], LastSID:[-], ChangedCount:0, SIDAuthOnly:No, MustValidate:No, MustRenew:No
        Work-Request Tracking: Validation Yes, Total 17, SID=[-], Violation 0, PSR 0, PSB 0
                Pending-WR: X/M/R=6/0/6, UDI=[PID:C1117-4PM,VID:V01,SN:FGL212991CZ], SID=[-], Correlator=[CiscoPnP-1.0-14-229-7F800A5060-12]
                Last-WR: X/M/R=2/1/0, UDI=[PID:C1117-4PM,VID:V01,SN:FGL212991CZ], SID=[-], Correlator=[CiscoPnP-1.0-13-229-7F7E7D5DB8-11]
        PnP Request Tracking: Current:[config-upgrade], Last:[cli-config], First:[device-info]
                Total:10, OK:9, Failed:1, LastFailed:[config-upgrade]
        PnP Response Tracking: Retry-Allowed 0, Total 0
                Last-PR: X/M/R=0/0/0, UDI=[PID:C1117-4PM,VID:V01,SN:FGL212991CZ], SID=[-], Correlator=[CiscoPnP-1.0-13-229-7F7E7D5DB8-11]
        PnP Backoff Time Tracking: Default 60, Current 60, Last 60, First:60, OK:2, Failed:0
        Countdown: Security Unlock: S=3/F=0/T=3068, Service Lock: S=2/F=0/T=0, Service Req Wait: S=0/F=0/T=18, Prxoy Req Wait S=120/F=0/T=0, Service Resp Ack: S=25/F=0/T=0
        Max message (RX) is 50 Kbytes
        XEP Faults are sent
        Idle timeout infinite
        Keepalive not configured
        Primary Transport:https to Host:pnpserver.mydomain.com, IP:?.?.?.?, Port:443, Src-Intf:-, VRF:-, URL pnp/WORK-REQUEST
        Backup Transport:https to Host:10.10.10.10, IP:IPv4, Port:443, Src-Intf:-, VRF:ad-1003, URL pnp/WORK-REQUEST
          backup excluded time 0 seconds, backup hold time infinite
  Connected to the primary transport via https
  Remote connection via HTTP client.  URL https://pnpserver.mydomain.com:443/pnp/WORK-REQUEST, post
  Established at 13:44:02.917 CET Wed Feb 7 2018
         Tx 32301 bytes (43 msg), Tx 24 errors,
         Last message sent at 13:55:00.998 CET Wed Feb 7 2018
         Rx 6403 bytes (19 msg), 0 empty msg
         Last message received at 13:46:50.742 CET Wed Feb 7 2018
As you can see it is is connected to primary and do not try to connect with backup transport.
Maybe someone has an idea how to fix it ?
IOS version  Version 16.6.2
APIC-EM Version 1.5.0.1368.
JPvisltgb
Level 4
Level 4
Found a workaround not sure is it ok.
Just added another pnp profile to config:
pnp profile pnp-zero-touch_2
transport https host 10.10.10.10 port 443 vrf VRF_NAME
After 60 sec router is trying to complete provisioning process through different profile.
