Cannot Access Production/POC Lab
james21970
Hello all,
just trying to use the labs to learn more about connecting to the API and when trying to connect to our own APIC API, I get the following:
This is an APIC running 1.1(3f).
thanks,
James
6 Replies 6
yawming
Please see troubleshooting section in the following doc.
Cisco DevNet: APIC Enterprise Module (EM) - Hello World GA
Yes, I have already. I can login using the aaaLogin mo, so I can hit the device with other requests, but this one from the lab isn't working.
Then you might try following the link "importing SSL certificates in chrome".
Is this your own lab ? If it is why using port 9443 ?
This is a standard production setup. And as far as why I'm using it, it's because it's in the lab docs. If another port needed to be used, then the lab should mention that in the section where it specifies to use your own IP address if using your own environment.
James
Agree with you that it should have more detail in the docs.
The apic-em is using default https port 443. Since Cisco DevNet Sandbox have EFT and GA release so we use 9443 for GA, and EFT version is still using 443. Will comeback to 443 once EFT lab is removed.
There is a deployment guide too.
http://www.cisco.com/c/en/us/td/docs/cloud-systems-management/application-policy-infrastructure-controller-enterprise-mo…
