Cisco ACI toolkit --> sandbox APIC exists?
vincentcabosart
I have downloaded the Cisco ACI toolkit (http://acitoolkit.readthedocs.org/en/latest/tutorialpackages.html#virtual-machine-for-vmware-environments) and I would like to know if there exists a sandbox APIC which I could use to test the toolkit.
I tried on this one: https://sandboxapic.cisco.com with the credentials: admin-secrete (with the aci-show-context.py of the toolkit for example) but I receive an error. Is there another sandbox APIC that I could use?
Thank you in advance,
Vincent
Geevarghese Cheria
Hi Vincent,
  First you need device id then only  Like -  "https://sandboxapic.cisco.com/api/v0/acl/device/"+id". You can call the script. And I think it wont be able to  test the ACI toolkit  with the devices in the sandboxapic.cisco.com.  Request to check the sample scripts on Github and tryout.
CiscoDevNet/apicem-ll-sample-code · GitHub.
Thanks and Regards,
Geevarghese
davbark2
Hi Vincent,
It’s true there is no sandbox for ACI (a.k.a. APIC-DC) yet, but you might be interested in exploring the various ACI demos on dCloud.cisco.com.  You’ll need to create a log in and then schedule one or more sessions from the Application Centric Infrastructure pull-down.
Also, the base URL for relevant Cisco sample code is https://github.com/datacenter.  The other one referenced in this thread is for APIC-EM, which is a different product altogether.
Dave
