Cisco prime network
How we can get the NetworkAlarmId associated to a ticket with a command?
If exist an BQL command to get all Network alarms, from the Cisco_Prime_Network_4-2-3_BQL_Integration_Developer_Guide.pdf manual we can’t find it?
lchaconz
If you are a CPN user, select the ticket and press F2 in your keyboard, you will have all the keys and parameters to make the BQL Query, but yes, it´s possible
