Cisco Prime Rate Limit settings
ed_rs
With my Java Client is there a way to determine the rate limits set on the Cisco Prime server that is described in the documentation via my code?
https://developer.cisco.com/media/prime-infrastructure-api-reference-v3-0/192.168.115.187/webacs/api/v1/index6945.html?id=rate-limiting-doc
Eddy
Spencer Zier
I'm not sure I entirely understand.  If you're asking if there's a way to fetch the current rate limit settings via the API, then unfortunately no.  Changing the values from their defaults (or checking the current values) requires CLI shell access.
I was wondering if there was an API to fetch the current rate limit settings on the Cisco Prime server.
Sorry for the confusion.
