07-17-2017 09:16 AM
Trying to migrate to the CMX 10.3 as we need AeroScout tag data and have run into a bug with 8.x where I am losing random tag data for hours at a time. We went to convert our integration tool to the 10.3 instance but found the REST API in 10.3 is not accepting the application/xml format. Was XML droped in CMX 10.3 REST API's? Hoping the answer is no because otherwise we need to rewrite our integration application.
07-17-2017 09:58 AM
Hi Eric,
Both JSON and XML is supported in CMX 10.3 REST API, just need to specify Accept application/xml in the header of the call.
Matt
07-17-2017 10:45 AM
I did try adding that and I get a 406 Not Acceptable when I do application/xml. If I change it to application/json, it works without any errors.
07-17-2017 02:03 PM
Hi Eric,
Maybe only Streaming notification JSON/XML are support. I see in the release notes for CMX 10.1 under Standards Based REST API the following, "Input and output of API uses the standard JSON format." That would indicate only JSON.
I apologize for not knowing this for sure, and will reach out the the CMX BU folks for verification.
Matt
07-17-2017 03:07 PM
Eric,
Got a reply - Both are supported, but we see 95%+ of developers using JSON.
Let me see what we are doing wrong. I will follow-up soon.
Matt
07-25-2017 11:39 AM
Eric,
Have you had any luck with getting XML responses from the latest API? At this point I think we should open a bug ticket against the API, getting error while using Accept: application/xml header.
Let me know,
Matt
