cobra.mit.request.CommitError: Token was invalid (Error: Token timeout)
huhe
I tried the following 2 methods, but no luck.
1, LoginSession.refresh()
2, first did LoginSession.logout(), then created a new LoginSession()
Any idea how to solve the issue?
Huan
Hello, when the token gets expired, what I do is a re-login. (No logouts, no refreshes just  login again.) It appears that currently Cobra SDK does not have a token refresh method either, unlike in ACItoolkit and PyACI modules.
FadiH
I have the same problem in my scripts. Did you find a way to solve this issue ? if yes, can you please share it ?
Many thanks
Fadi
