Highlighted
Beginner
configuration manipulation with APIC-EM
I am trying out the API of APIC-EM and I encounter problems in updating interface fields like : IP/mask, speed/duplex, description, mode.
Here is an example:
The POST body is:
        "ipv4Address": "10.10.30.1",
        "ipv4Mask": "30",
        "id": "edbc9c9c-eef9-4f57-a6bd-4f07c902b557"
Request URL
https://10.10.10.107:443/api/v0/interface
Response Body
{ "response": { "taskId": "917c54d5-0bd6-4b53-a04e-56822837ebed", "url": "/api/v0/task/917c54d5-0bd6-4b53-a04e-56822837ebed" }, "version": "0.0" }
Task is ok:
Request URL
https://10.10.10.107:443/api/v0/task/917c54d5-0bd6-4b53-a04e-56822837ebed
Response Body
{ "response": { "id": "917c54d5-0bd6-4b53-a04e-56822837ebed", "rootId": "917c54d5-0bd6-4b53-a04e-56822837ebed", "serviceType": "Inventory service", "progress": "Interface updated successfully #edbc9c9c-eef9-4f57-a6bd-4f07c902b557 ", "startTime": 1430148662699, "endTime": 1430148662725 }, "version": "0.0" }
With GET we see the updated info, also in the GUI
result is: {
    "version": "0.0",
    "response": {
        "macAddress": "FC:5B:39:D4:4C:01",
        "vendor": "Cisco",
        "ipv4Mask": "30",
        "duplex": true,
        "serialNo": "FGL183710LP",
        "pid": "ISR4451-X/K9",
        "lastUpdated": "2015-04-27 15:30:12.629034+00",
        "status": "up",
        "numUpdates": 534,
        "interfaceType": "Physical",
        "deviceId": "5a89d2c4-9613-4a2e-900a-4122a900788a",
        "portName": "GigabitEthernet0/0/1",
        "portType": "ISR4451-X-4x1GE",
        "ospfSupport": true,
        "connectorType": "RJ-45",
        "id": "edbc9c9c-eef9-4f57-a6bd-4f07c902b557",
        "speed": 1000000,
        "avgUpdateFrequency": 181
BUT in reality, the configuration on the network element is not updated:
ISR4451X-B#sh run int gi 0/0/1
Building configuration...
Current configuration : 194 bytes
interface GigabitEthernet0/0/1
description P2P link to 3560-X
ip address 10.10.30.65 255.255.255.252
speed 1000
no negotiation auto
service-policy input PM
service-policy output PM
end
ISR4451X-B#sh ip int gi 0/0/1
GigabitEthernet0/0/1 is up, line protocol is up
  Internet address is 10.10.30.65/30
  Broadcast address is 255.255.255.255
Is there a specific issue or I am not doing it in the right way?
I have also tried to delete and post a new interface but still does not work.
Thank you,
Cristian Ruta
ruta.cristian@gmail.com
Everyone's tags (4)
1 ACCEPTED SOLUTION
Re: configuration manipulation with APIC-EM
The /interface API is NOT for changing device state
1 REPLY 1
Content for Community-Ad
August's Community Spotlight Awards
